They jacked that logo from X men !
Not bad looking for just protectors
AA Poly 6.5 on the left DD W6.5 on the right
DD W 6.5 on the left AA Poly 6.5 on the right
Phase plug, looks like its part of the cone but its not
DD W6.5 weighing in at a whopping 4lbs 15oz
AA Poly at a measly 2lbs 1oz
AA Poly 6.5 7" basket
p40600164re.jpgDD W 6.5 6.5" basket
P.S
These suckers MOVE...wowza
They put the DD's to shame.
At higher excursion you get tinsel lead slap, but you have to have them turned up pretty loud.
Lower volume's its fine.
The reaason being is because whoever designed the terminals is an idiot.
They put the + on one side and the - on teh opposite side. They left the tinsel leads to long.
The leads come directly off the coil, not through the cone like most woofers.
Thats why they hit.
dope. we'll see how they compare to the extremii.
Wow, yeah those tinsel leads are totally retarded. YOu should contact AA about it, see if you can get a change made and help em out.
That phase plug is teh purdy tho' :)
suweeeeet....if you x them over at a higher point, will the noise be there?
me likey, me likey alot. Though ported will take up alot of room, maybe it will stop the slap. Another thing you could do is glue some felt where the leads are hitting the cone. The coak's i got from Flakko had that done between the tweeter and the cone. realt phase plugs FTW. get some vid of it getting stroked :D
nice pix
There is no noise.
You almost have to get it to dance on the back plate to get them to make noise.
They just made them to long, thats all
Just remember that the extremis are 3x the price.
But that could be for a reason....
the cone feels REALLY REALLY flimsy... although i do like that flat black look to them and hte phase plug is realy cool
my dynas with prwan them. lol
that sweet man i bet they sound sweet. you should get a AA sub off ca.com.. going around..
They prob do, but they werent $35 each :P
but my adire mids were cheeper... and sill pwn yours too.
muhahah
Is that actually a real phase plug? I can't tell whether that glue is just holding the cone to the former or if it's actually gluing the "phase plug," Which would make it nothing more than a dust cap. They look exceptional for $35 drivers.
- Driver Features -
- Solid Copper shorting sleeve
- Solid Aluminum phase plug
- Split coil design flat-BL design
- Ultra low distortion
- Extreme excursion - 11.5 mm one-way
- Opposed tinsel leads for linear performance at higher excursions
- High quality spider
- Rubber surround
- Open frame cooling vents for voice coil
- Curvilinear cone profile
- Ultra low inductance
- Flat and extended frequency response
- Incredible bass output in sealed or ported designs
- Infinite/open baffle compatibility
- Neodymium motor structure
- Detailed sound
- High output capability
- Cast metal frame
- Fully sheilded design
- Light weight and easy to mount
- Reflection free compact motor structure
Edited by CBFryman
THey but the terminals on oposing sides to distribute weight and tension evenly...
You know.... FYI.
The leads are indeed XLong
Yes.
I tried to focus it but i just wouldnt work.
When i saw pics i thought the phase plug was fake and was just glued on the cone.
The distance between the 2 is very small, thats why it looks that way.
