Posted March 31, 201312 yr I have one positive run to the back. Will that support a 3500d?I have a 3400 with stock under the hood. I am thinking another 3100 in the back.All grounds are to frame to avoid chopping the car up.Thanks for the help its been awhile since I been here.lol Edited March 31, 201312 yr by Fearz
March 31, 201312 yr Two runs of 1/0 awg, both pos and ground. Run a D3100 in the rear. Two runs will be plenty and then some in case your system grows and you decide to strap another 3500d
March 31, 201312 yr Never a reason to run separate ground wires 99% of the time. Waste of money. Normally, you make your electrical system worse by running the separate ground...
April 12, 201312 yr Never a reason to run separate ground wires 99% of the time. Waste of money. Normally, you make your electrical system worse by running the separate ground...Can someone please explain this to me? how does running separate ground wires make your electrical worse?
