So I'm getting a voltage drop to 13.8 after the second song or so
I check with my voltmeter i bought cause some1 on here told me i better buy 1
and the reading is 14.4 before the fuse
13.8 after
i'm wondering if this is from the resistance the warm fuse?
im running the proper size fuse
1 run of 1/0 gauge
now what I really want to know is if the drop is from the fuse resistance
is this something i should worry about going full tilt?
should i add another run of 1/0 gauge?
(i have 20ft of knu ofc forsale/laying around but id have 2 buy another fuse)
stock alt
2 yellow tops
hifonics colossus bridged @ 2ohm  (3600 watts supposedly)
RF p400.2 -mid
RF p200.2 -high
(2) DD 2512
also at red lights when going full tilt i hit 12.3-12.1
is it dangerous to play loud at that voltage level?
what if it dips to 11.8?
Thanks
 the 14.4 before and the 13 after i would look into what kind of fuse holder you have.. it seems to be cunducting poorly,  check the connections and look for any corrosion and so forth
 adding another run would not hurt.
  why would you play your stereo full tilt at a redlight, that is rude, and give car audio a bad name.  please stop,
 but yes,  your amp will start clipping, and your amp can catch on fire from playing with low voltage, not saying it will at 12 volts. but 10 volts yup it sure can.
Are you measuring right at the fuse?
Oh for some reason i thought he meant right after the fuse .. not at the end of his run
Thats what I assumed, across the fuse not at the amp.
I assumed he meant right after as well the way it was worded. If you meant it was 14.4 up front and 13.8 in the back, that might be just the wire heating/warming up and causing a bit more resistance.
If you guys are assuming right, the reason for a drop in voltage in the rear is their is no ground run from front to rear.
Every vehicle out there i've measured loses between 0.3-1.2v by not having a ground run.
The way I read it he was measuring right before and right after the fuse....
And if that's correct, jon is spot on, that's a BAD holder
And, hehe, if that's the case, i'm ALMOST..... pretty close, willing to bet it's a knukonceptz fuse holder if the voltage drop actually occurs as part of the block\fuse itself.
No h.o alt?
that is right, knu fuse holder
No h.o alt?
nope
i got a run of 1/0 gauge from from battery (-) to rear batt (-) too
man i was impressed til you said that shit about not going full tilt at the red light
when i play loud at red lights there is no other cars around me
infact rarely are there any cars around me out here
and i just used red light as an example of the car stopped
i see it when i demo at my friends too
no corrosion, fresh equipment
and its 14.4-14.2 before and 13.8 after not 13
and yes guys i was testing right around the fuse
as i am noob and there is a little wire showing on both ends
I'm so lost as to how a fuse holder can cause this problem
when a fuse holder is so simply designed and applied
ive heard alot of bad stuff about knu fuse holders and dist blocks
so what is the recommendation?..............
add another run?
change to a diff fuse holder?
keep it as is since 13.8 is as low as it sits?
You should probley be good. Iv seen some peoples car show the high 13s always. Couldn't hurt to try a different fuse holder just to see if there is a difference
It's not just other cars but people who live near by.
J
If you really want to be sure it is the fuse holder, measure the drop across the holder.  Put one test lead on the input of the holder and one on the output.  Put it on DC volts.  With your system playing, what is the highest reading you get?
Until you do this, it is speculation about the holder...
troll?
the way how their furrow fittings work sucks.
I'm curious on something though since that much voltage drop across just a few inches is rare.. how hot does it feel if you place your hand over and around the fuse holder?  Feel both ends, does any of it feel warm or hot?
It should feel cold.
troll?
Your joking, right?
troll?
Absolutely not! He is on the Tech team for a reason!
troll?
troll?
I don't get it?
troll?
troll?
I don't get it?
he is telling me something to do
that i have clearly done
its either lack of reading or trolling so idk sorry
it is a little warm all around but not so much that i cannot touch
i'm nervous about how much worse things will be in the summer
ive had problems with scosche fuses
i figured going with knu i would be ok.....
It seems a little off though because I am only running a stock alt
its not like im pushing 220 amps through the fuse
and it is a 300 amp fuse anyways
idk maybe the fuse holder is way less conductive
than my ofc 1/0 gauge
so when the current hits the fuse it has issues
all thats guessing tho
i just thought a fuse holder is only 2 pieces of metal
how dumb does a company have 2 be 2 mess it up
no you measured voltage. hes telling you to measure the resistance of the fuse holder.... NOT the same thing.
