Posted May 3, 201312 yr I just built a new enclosure and was wondering if 118 inches of port tuned around 31hz ok for my 4 fully loaded BL 12's?
May 3, 201312 yr I just built a new enclosure and was wondering if 118 inches of port tuned around 31hz ok for my 4 fully loaded BL 12's?That should be good. Use a bit more if you can though.
May 29, 201312 yr so when you add more than one woffer to a box you need to increase the size of the box itself for cubic feet but not the port area? so a sub that needs 5 cubic feet, when putting 2 i a box they would need 10 cubic? but they both would use the same port area for single or dual right? assuming they are sharing a single port. is that right?
May 29, 201312 yr port area depends mainly on 3 things, tuning. Xmax and sub size. The higher the tuning the more port area.. Also the more you can displace the more port area you will need.
May 30, 201312 yr Author This question is really technical. The 4 BL subs I have were from when FI made them available with 4 inch coils. I recently had them reconed but I believe they were reconed with maybe SP4 coils since they are 4 inch. If so does this alter how I should build my enclosure since the SP4 coil is longer than the standard BL coil?
May 30, 201312 yr port area depends mainly on 3 things, tuning. Xmax and sub size. The higher the tuning the more port area.. Also the more you can displace the more port area you will need. Vas, Tuning, and Power. *The lower the tuning, more port area is needed. Edited May 30, 201312 yr by stefanhinote
May 30, 201312 yr This question is really technical. The 4 BL subs I have were from when FI made them available with 4 inch coils. I recently had them reconed but I believe they were reconed with maybe SP4 coils since they are 4 inch. If so does this alter how I should build my enclosure since the SP4 coil is longer than the standard BL coil?I wouldn't sweat it.
May 30, 201312 yr port area depends mainly on 3 things, tuning. Xmax and sub size. The higher the tuning the more port area.. Also the more you can displace the more port area you will need.Vd, Tuning, and Power.*The lower the tuning, more port area is needed.Power can be completely removed (its literally not in the equation). If you do then you might as well include box volume which affects Q and affects power needed to accelerate the piston to xmax.
May 30, 201312 yr port area depends mainly on 3 things, tuning. Xmax and sub size. The higher the tuning the more port area.. Also the more you can displace the more port area you will need.Vd, Tuning, and Power.*The lower the tuning, more port area is needed.Power can be completely removed (its literally not in the equation). If you do then you might as well include box volume which affects Q and affects power needed to accelerate the piston to xmax.I should have said vas instead of vd. I've been using this: http://s0.wp.com/latex.php?latex=\frac{13.7\sqrt{\frac{9.64+\times+10^{-10}+*+fs^3+*+vas+*+power}{qes}}}{Fb+*+R^2}&bg=ffffff&fg=000&s=3from the loudspeaker book. Is there another equation that implies the driver reaches full excursion, so it doesn't require power? Edited May 30, 201312 yr by stefanhinote
May 31, 201312 yr I don't remember that formula. WHat's it for? I prefer to let Mathcad do the work being that it is frequency dependant but here you go. Im going off a file off my phone but I think this is all of it. Pmax= (k1/Gno)(Fn4 - C x Fn2 + A)^2 + Fn2 x (D x Fn2 - B) / Fn4 - E x Fn2 + A^2 K1= (4 x pi^3 x Ro / c) * Fs^4 x Vd^2 Ro= density of air (1.18 kg/m^3) C= 1 + A + (vas/vb) + Fb / 7 x Fs x qts) Gno= 10^((spl-112)/10) spl= reference efficiency Fn4= Fn2^2 Fn2= (F/Fs)^2 F= frequency C= 1 + A + (Vas/Vb) + Fb / (7 x Fs x Qts) A= (Fb/Fs)^2 D= 1/Qts + Fb / (7 x Fs) B= A/Qts + Fb / (7 x Fs) E= (97 / 49) X A
May 31, 201312 yr I don't remember that formula. WHat's it for? I prefer to let Mathcad do the work being that it is frequency dependant but here you go. Im going off a file off my phone but I think this is all of it. Pmax= (k1/Gno)(Fn4 - C x Fn2 + A)^2 + Fn2 x (D x Fn2 - B) / Fn4 - E x Fn2 + A^2 K1= (4 x pi^3 x Ro / c) * Fs^4 x Vd^2 Ro= density of air (1.18 kg/m^3) C= 1 + A + (vas/vb) + Fb / 7 x Fs x qts) Gno= 10^((spl-112)/10) spl= reference efficiency Fn4= Fn2^2 Fn2= (F/Fs)^2 F= frequency C= 1 + A + (Vas/Vb) + Fb / (7 x Fs x Qts) A= (Fb/Fs)^2 D= 1/Qts + Fb / (7 x Fs) B= A/Qts + Fb / (7 x Fs) E= (97 / 49) X AIt's the formula for vent mach from the loudspeaker cookbook. Pretty close if not the same as WinISD iirc.
