Posted June 20, 201312 yr has anyone ever heard just one of these subs in a 350z. i'm thinking about running one off a jl audio 300/2 amp at 2 ohm in my 08 350z.
August 5, 201312 yr i have 2 of these in my 350z. struggling with frequency though. not enough room for box or air space. Thinking of going with a sealed box. i had a single JL 12W7 first it was way worse, of course. http://www.caraudio.com/forums/enclosure-design-construction-help/574003-help-ported-box.html
August 5, 201312 yr i have 2 of these in my 350z. struggling with frequency though. not enough room for box or air space. Thinking of going with a sealed box. i had a single JL 12W7 first it was way worse, of course. http://www.caraudio.com/forums/enclosure-design-construction-help/574003-help-ported-box.htmlthe SA-8s will not work well in a sealed box. dont do it!
August 14, 201312 yr Author i figure 2 8's would be way to much for a 350z that is why i figure i go with 1 8 but not sure if it be a good ideal ?
August 14, 201312 yr The SA-10s are the same price, aren't they? Just do that and put it in an appropriate box.
August 15, 201312 yr Author what size box u think would be great for my 350z ? ill be tuning it around 33-35hz. ill be putting about 500 rms to it. Edited August 15, 201312 yr by john k
August 15, 201312 yr Author so with the limit amount of space i have to work with u think i could run 1 sa 10 in my car with 500 watts ?. 26 1/2" w x 20 1/2" d x 9 1/2" h
August 15, 201312 yr so with the limit amount of space i have to work with u think i could run 1 sa 10 in my car with 500 watts ?. 26 1/2" w x 20 1/2" d x 9 1/2" hYes
August 15, 201312 yr well that is good news then how big of a box could i build ? 26 1/2" w x 20 1/2" d x 9 1/2 Haha Which equals 2.2 before displacements.
August 15, 201312 yr Tuning low, with port area, in a small box is a waste...and what you are stuck with when using a single 8".
August 15, 201312 yr Author Tuning low, with port area, in a small box is a waste...and what you are stuck with when using a single 8". I'm sorry but i don't think i understand what you are trying to tell me here
August 15, 201312 yr Tuning low, with port area, in a small box is a waste...and what you are stuck with when using a single 8". I'm sorry but i don't think i understand what you are trying to tell me hereSay no to the ported 8" sub idea. Edited August 15, 201312 yr by ricksi30
August 15, 201312 yr Your port will take up more space than the net space of your box. ie, choose differently
August 15, 201312 yr Author I figure I will go with a single 10 I will just need to figure out what size of a box I will need to build for the sub .
August 15, 201312 yr You could do a decent sized sealed box and stuff it with polyfil. I'm doing a sealed box, currently. Should be much better than any stock sub I've ever heard, and loud in your small car.
August 16, 201312 yr Holy crap, I had no idea you were talking about the box I was building! ...Mine's for a fifteen. I was saying your ten in a sealed should get loud in your small car. Upon rereading, I see where my sentence is awful. lol
