November 5, 201411 yr Author Attended my first bass race last week and ended up scoring this on completely stock electrical.
November 6, 201411 yr Author Upcoming design im thinking about giving a shot.not to scale or anything, just a rough estimate of what im thinking.
November 6, 201411 yr Or theres my 2nd design. What do you guys think? Any input?I prefer this look. Just out of curiosity, why all the 8's? I'm not trying to bag on your setup, just wondering why not use a larger driver and less of them.
November 7, 201411 yr Author Or theres my 2nd design. What do you guys think? Any input?I prefer this look.Just out of curiosity, why all the 8's? I'm not trying to bag on your setup, just wondering why not use a larger driver and less of them. dont know how the numbers are going to look with the port covered mostly by the seat but can give it a go if i decide to go this route. As far as why... well i had 6 already so might as well get 6 more. Plus havnt seen a wall done with 8's before. Would be pretty unique and one of a kind. Again, don't know how the numbers will stack up tho...
November 7, 201411 yr That's right I never thought about the seat... It is unique, and it's kinda cool watching all those little subs getting down. 6 more would be chaos.
November 7, 201411 yr Author Not trying to turn this into a poll or a design thread, just looking for input before i start to build the false floor and design/plan further.
November 10, 201410 yr Author Update: Just placed my order for another 6 SA-8 V2's. Should get here around friday
November 12, 201410 yr One of my favorite Jeezy songs, i bet it sounds good in there. Electrical upgrades FTW!
November 16, 201410 yr Author Update: UPS delivered me my other 6 subs that i ordered. I also picked up an XS battery, as well as made an amp rack in preperation for my other 3 amps i will be getting soon. Enjoy
November 17, 201410 yr Author Amp rack will be killer once done yessirr! so eager to get the funding for the other 2 3500's, then i can start on the extension of the amp rack to accommodate my mids and highs amp
November 18, 201410 yr Author About to order my mids and highs and am planning on running a 5K High pass filter crossover with them. The website specifies that they can handle 250 watts RMS and are rated at 8ohm. I am planning on getting 4 selenium 8ohm tweeters and running them in parallel to have a final ohm load of 2. My question is, do i only need 1 crossover which would be wired right at the exit of the amplifier channel before it goes into the 4 selenium tweeters or do i need to wire a 5K high pass crossover to EACH tweeter and THEN wire them in parallel?Hope that made sense.
November 18, 201410 yr If they block frequencies at 8 ohms then put a crossover before you add the wires rogether and drop the load. It would be hard for a crossoveer rated at 8 ohms to effectively work at 2ohms.4 super tweeters is a waste, 2 will be more than adequate. Edited November 18, 201410 yr by jay-cee
