Last Teasers before the official video demo.
  • 3 weeks later...
  • Replies 86
  • Views 18k
  • Get a single set of components and use one of the sundown amps as a two channel bridging ch 1&2 and 3&4 to each side; or two raw 6.5s and two tweeters for an active setup.
  • Progress update. New enclosure and another SA-8.V2 + A new toy.
  • Update: UPS delivered me my other 6 subs that i ordered. I also picked up an XS battery, as well as made an amp rack in preperation for my other 3 amps i will be getting soon. Enjoy
Attended my first bass race last week and ended up scoring this on completely stock electrical.
Upcoming design im thinking about giving a shot.
not to scale or anything, just a rough estimate of what im thinking.
looks loud
What size subs? Also what brand?
Or theres my 2nd design. What do you guys think? Any input?
Sundown SA-8 V2's
I prefer this look.
Just out of curiosity, why all the 8's? I'm not trying to bag on your setup, just wondering why not use a larger driver and less of them.
I prefer this look.
dont know how the numbers are going to look with the port covered mostly by the seat but can give it a go if i decide to go this route. As far as why... well i had 6 already so might as well get 6 more. Plus havnt seen a wall done with 8's before. Would be pretty unique and one of a kind. Again, don't know how the numbers will stack up tho...
That's right I never thought about the seat...
It is unique, and it's kinda cool watching all those little subs getting down. 6 more would be chaos.
Not trying to turn this into a poll or a design thread, just looking for input before i start to build the false floor and design/plan further.
Update: Just placed my order for another 6 SA-8 V2's. Should get here around friday
One of my favorite Jeezy songs, i bet it sounds good in there. Electrical upgrades FTW!
Looking great so far!!
Amp rack will be killer once done :droolcup:
yessirr! so eager to get the funding for the other 2 3500's, then i can start on the extension of the amp rack to accommodate my mids and highs amp
About to order my mids and highs and am planning on running a 5K High pass filter crossover with them. The website specifies that they can handle 250 watts RMS and are rated at 8ohm. I am planning on getting 4 selenium 8ohm tweeters and running them in parallel to have a final ohm load of 2. My question is, do i only need 1 crossover which would be wired right at the exit of the amplifier channel before it goes into the 4 selenium tweeters or do i need to wire a 5K high pass crossover to EACH tweeter and THEN wire them in parallel?
Hope that made sense.
If they block frequencies at 8 ohms then put a crossover before you add the wires rogether and drop the load. It would be hard for a crossoveer rated at 8 ohms to effectively work at 2ohms.
4 super tweeters is a waste, 2 will be more than adequate.
Edited by jay-cee
Old box is out and getting ready for the wall build
3/4 inch birch for the false floor/foundation
The calm before the storm.
You know your a basshead when.....
