Posted July 13, 201312 yr since all the kiddies like videos, here is the Ethos 15 on ~1,750 watts. Mind the jerry rigged set up. I don't currently have a large enough battery supply in my shop to run my power convertor on a large amount of power.
July 14, 201312 yr Author Damn! These look they could be fun!I'm pretty humble so ill say parts and excursion wise they aren't any different than any other driver rated for 32mm xmax as I use the same parts from the same source as nearly every other reputable manufacturer. There are only two things different with this driver 1st the price. They will be priced at ~$350 SHIPPED. 2nd they are specifically designed to work in small enclosures. The 12 in 1.5 cft ported and the 15 in 3cft ported. These volumes tuned to 32 hertz produce the lowest rolloff with only a slight ripple gain in response.
July 17, 201312 yr Author is that a single 15? is that a single 15?well yea, I's only gots one motor at the moment. Were you expecting more. I realy didnt want to start dissapointing people this early. Edited July 17, 201312 yr by Quentin Jarrell
July 17, 201312 yr no that was great, with all the windshield flex i was whoad, very impressive for a single 15 cant wait to see more !
July 17, 201312 yr Author Iphone wouldn't pick up most of the flex but you see a little movement by the window switches.
July 18, 201312 yr nuway went out of business....all remaining toolings and parts were bought out by lcc a few years ago
July 18, 201312 yr Author nuway went out of business....all remaining toolings and parts were bought out by lcc a few years agoNo, Nuway did not go out out of business they were bought by Loudspeaker Components. When you call and talk to Neil he still calls it Nuway. When you call Rafiel in Mexico the receptionist answers the phone as Nuway. When the spiders come the packaging is labeled as Nuway. Nuway builds spiders in Mexico. LCC builds bodies and edges in the US. Same owner different companies.
July 18, 201312 yr Are you setting up your own jigs and build from scratch or will the parts be assembled off site? What type of materials? All of the subs going to have progressive spiders?
July 18, 201312 yr Author All drivers are built and charged by Nick Wright. My spiders are nomex cotton blend with a 1.72 creep.
