Posted July 24, 201313 yr I have a 98 s10 ext cab, have not chosen box specifications, or an amp yet. For the amp I'm thinking about getting a 1500 watt audiopipe. For the box I plan to go ported. Which would be louder and with deeper bass 2 12" gcons which are 750 rms or 1 12" icon which is 1250 rms? Edited July 24, 201313 yr by Stephen93s10
July 24, 201313 yr Popular Post I have a 98 s10 ext cab, have not chosen box specifications, or an amp yet. For the amp I'm thinking about getting a 1500 watt audiopipe. For the box I plan to go ported. Which would be louder and with deeper bass 2 12" gcons which are 750 rms or 1 12" icon which is 1250 rms?If both were in proper enclosures the two gcons would be louder. I would suggest looking for a different amp.
July 24, 201313 yr Author Any suggestions I dont have a lot to spend though.try to keep it under 350$ if possible
July 24, 201313 yr Any suggestions I dont have a lot to spend though.try to keep it under 350$ if possibleI'm very happy with my ppi bk amps.
July 26, 201313 yr You said that your total budget is 750 right? Can you build your own enclosure if we help?
July 26, 201313 yr Admin Under 350$ for the amp. That about 1500 watts Worry less about power and more about the install & enclosure.
July 26, 201313 yr I am running 1500 wrms to a 12" SSA zcon and it is loud!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
