August 23, 201312 yr Here ya go Give us some info! I never did see a preorder either What is the goal of this bad boy? Specs?
August 23, 201312 yr Author This is the Top Dog of subwoofers for IA. 3" 8 layer flat aluminum coil, 8 neo columns, dual woven leads, 3500 watts rms. Cooling is greatly increased over the previous model.
August 23, 201312 yr Not seeing them on your website... Will you provide specs as well? Or would I have to ask specifically for my sub after testing my sub? What sizes are available?
August 23, 201312 yr Author Website has not been updated because the new product is just now coming out. We will get the products out and then update the website. If you would like to order any of the new stuff then you can call IA directly and they will point you in the direction of the closest dealer or if there isn't one close then you can buy directly from IA. I already posted the info on the woofer. IA will provide recommended enclosure spec as well.
September 7, 201312 yr Thinking 2 21s walled in a 2013 Chrysler 300 and an NS1 Impulse thought but I might actually do this...
September 12, 201312 yr Admin when will they be available in the ssa store? Yessir, ready for purchase... http://store.soundsolutionsaudio.com/categories/sub-woofers/incriminator-audio/warden.html
October 16, 201311 yr Are you guys going to be posting pictures of each size warden in the store? I haven't seen a picture of the 21 or 18 anywhere yet.
