Posted August 10, 201312 yr This label will be attached to the outside of the shipping packaging for product identification
August 11, 201312 yr Could you please not put that on the outside. Far too many thefts and careless activities may go on with this info on the outside.
August 11, 201312 yr Author Could you please not put that on the outside. Far too many thefts and careless activities may go on with this info on the outside.ALL packages will be insured and EVERY package will be direct signature. I will NOT allow FedEx to leave packages unattended.
August 11, 201312 yr will they be double boxed? with other companies they have a box that the sub is in, with packing, and it has all the info on the label and then its inside another plain box for shipping
August 11, 201312 yr not what i said, infact the subs im speaking of are not made in china either,. ok tho just asking ... sheeshh
August 11, 201312 yr Author They will packaged in a 250lb rated box with OSB board on top and bottom. The motor will sit in a small box attached to the OSB to keep it from shifting and the basket will have foam supports around it to keep it from shifting.
