Posted August 23, 201312 yr It is a process and learning experience in the making.I have been doing builds for about 6 or 7 years now (been slacking last couple years lol), but never had a vehicle i wanted to sacrifice for a wall. Well i do now... The build is going to be a few months in the making. Or years as most walls are and change a lot over the course of their life. Product list. 1995 Eagle Talon EsiI haven't decided on head unit yet. Looking for a decent double din, or a nice Single din.2 18" Sundown Nightshade V1 motors (not sure on drop in yet.) Looking at psi or ZV3.1 Crescendo BC55004 deka 9a31's100+ ft of AT 0 gaugeSinger 190 amp alt with external regulator2 PRV 4 inch horns2 PRV 8's4 3" dayton fullranges2 4" dayton mid rangesmb Quart ref 50.4Crunch prz 1600.4Looking at deadner still. (SDS or AT) For some reason My computer will not allow me to upload pictures So thats going to hae to wait until tomorrow. Sorry Ha! Edited September 10, 201312 yr by mdizzle5472
August 23, 201312 yr Author 10 lbs of shit in a 1 lbs bag ehh? I think 600 pounds would be a more accurate guess. Hah
August 23, 201312 yr Author Sounds good, I would scratch some of those mids or the horns.I already have the horns, they re gong to be mounted under dash more than likely with not a lot of power to them. The 3" will be in a pillar and the 8's and 4's will be in doors. I Thought about scratching the 4's in the doors and may still, basicly they would be kind of pointless and wouldn't really be able to aim them correctly to make a difference.
August 23, 201312 yr Just keep it simple, an 8" and horn in each door. No 3" or 4" from Dayton, just too much going on in my opinion
August 23, 201312 yr Author Just keep it simple, an 8" and horn in each door. No 3" or 4" from Dayton, just too much going on in my opinionI will definately take that into consideration. I have yet to order any of the mids yet, so Can try out the 8's and horns first and see how i like it. Thanks bro
August 23, 201312 yr Welcome back Mikey!! Eagerly awaiting the pics You got a little bit of Shizzzon in this build.....LOL!
August 23, 201312 yr no problem, I been in this situation of putting a ton of speakers in for just the front stage. Over the years of learning and being on this site it can be done with less equipment. Sound just as loud and tons better.
August 23, 201312 yr Just keep it simple, an 8" and horn in each door. No 3" or 4" from Dayton, just too much going on in my opinionYep, as in WAY TOO FUCKING MUCH. It'll only detract and not help. KISS first, then see.
August 23, 201312 yr I agree with the other guys as well. The best move would be to KISS with the minimal amount of speakers along with decent power & good processing.
November 17, 201312 yr Author Also decided to just stick with the prv 8's and 4" horns. And picked up 2 saz 3500's to power the nightshades, even though it will be a bit much for them in all reality.
November 18, 201312 yr Also decided to just stick with the prv 8's and 4" horns. And picked up 2 saz 3500's to power the nightshades, even though it will be a bit much for them in all reality. If you went with the nsv1 and zv3 parts, then it will not be too much. Have a local here running 2 4500's per 18" with extremely similar setup on the sub. He currently does around a 65 with em.
November 18, 201312 yr Author Was Also decided to just stick with the prv 8's and 4" horns. And picked up 2 saz 3500's to power the nightshades, even though it will be a bit much for them in all reality. If you went with the nsv1 and zv3 parts, then it will not be too much. Have a local here running 2 4500's per 18" with extremely similar setup on the sub. He currently does around a 65 with em. I have a zv3 drop in on a nightshades that's built as a 12" now. There were 2 til I blew the spiders gave out on one. Lol. I was thinking about sticking with them, but also looking at psi and Tantric.
November 18, 201312 yr Author For an update I just finished sanding all the resin and inside of the enclosure. Depending on temperature tomorrow I will be throwing 2nd layer of fiberglass resin in. Then sand again and go from there. Still need to cut front baffles, build battery and amp rack, run a bunch of wire, build doors, buy batteries and recones. Buy some carpet because a can of expanding foam blew up in the car. (was not cool) lol
November 18, 201312 yr Author Nice progress if first layer is already knocked down!Yep laid it yesterday and sanded it down today. Also may have new job soon... With att... Installing Uverse....
