Posted April 23, 200620 yr I want to get one or two XXX the 06 model not sure 15" 12" or 18" yet i need to get more info. what are some suggestions on powering these bad boys? AX? or MD2? Edited April 23, 200620 yr by budros
April 23, 200620 yr I want to get one XXX 18" the 06 model what are some suggestions on powering this sub? AX? or MD2?<{POST_SNAPBACK}>You prob want something around the 3-4Kw area AX3000, if you are prepared to dish out A LOT of money
April 23, 200620 yr Author money isnt the issue , im not putting 4K intoa system thats ok. I would rather put 7 into a pucking amazing one.
April 23, 200620 yr Cool with me Thats what you will need to use if you want to use a US Amps amp.Not shure if you have seen any videos but with 1500W the thing doesnt get any where near x max
April 23, 200620 yr 1 xxx i would use a single AX3000DE haha tha would be sweet...in the future, i want to use a single 15 or 18" XXX with an AX2000 on each vc oh and you DO know that the AX3000DE retails at 3k right ?
April 24, 200620 yr 1 xxx i would use a single AX3000DE haha THE would be sweet...in the future, i want to use a single 15 or 18" XXX with an AX2000 on each vc oh and you DO know that the AX3000DE retails at 3k right ? <{POST_SNAPBACK}>i swear us amps are worse than a gambling addiction man
April 24, 200620 yr or you can use that mlt, and wire the subs together, and you wont have to match gains
April 24, 200620 yr way to much money for a sub, IMHO. Should be nice though if you buy all of that stuff .
April 24, 200620 yr way to much money for a sub, IMHO. Should be nice though if you buy all of that stuff .<{POST_SNAPBACK}>kinda ironic that you would be behind a 3,000 amp but not a 7-$800 sub.Also ironic because you have an adire audio symbol as your avatar....and though the tumult is no slouch, dollar for dollar not an '06 XXX
April 24, 200620 yr to cause no troubles, i fotgot the whatever..i guess ever forum has to have it's re fanboy. an di guess your ours.... wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
May 5, 200620 yr way to much money for a sub, IMHO. Should be nice though if you buy all of that stuff .<{POST_SNAPBACK}>kinda ironic that you would be behind a 3,000 amp but not a 7-$800 sub.Also ironic because you have an adire audio symbol as your avatar....and though the tumult is no slouch, dollar for dollar not an '06 XXX<{POST_SNAPBACK}>wait, the new amp cost's 3 grand? the old ones were around 1500, i snagged mine up for 700. if this is the case, i wont be able to afford any more us amps..
May 6, 200620 yr to cause no troubles, i fotgot the <{POST_SNAPBACK}> whatever..i guess ever forum has to have it's re fanboy. an di guess your ours.... wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee <{POST_SNAPBACK}>*cough* Memphis *cough**cough* Kicker *cough**cough* boxes tuned too high *cough*I be all about some Memphis, though...the Sync6's were definitely a good choice.
