Posted October 26, 201312 yr All info on the 12 inch Ethos will be located here. Still working on large signal parameters. For now here are the physical dimensions of the driver.
November 26, 201311 yr enclosure rec???? please All info on the 12 inch Ethos will be located here. Still working on large signal parameters. For now here are the physical dimensions of the driver.
November 26, 201311 yr enclosure rec???? please All info on the 12 inch Ethos will be located here. Still working on large signal parameters. For now here are the physical dimensions of the driver. For the 12? If so I believe Quentin told me 1.5 @ 32 or 34 depending on what kind of response you are looking for.
November 26, 201311 yr Author still working on finalizing as I'm waiting on final large signal parameters. They will be 1.5 cubic feet tuned ~32 hertz. I won't be able to give final specs until. However I have sample parameters which are as followed. These are in the ball park but I added mass to the cone and adjusted the spider pack a bit. well I don't have a Klippel viewer on this computer give me about 30 minutes while I download one
November 26, 201311 yr Author below is the sample and is not final production. You will see when modeled a dip or saddle in response in the 40-60 ish range when modeled in the recommended 1.5 tuned ~32. This has been addressed and why I'm awaiting final parameters. re 1.5qms 9.48qes .36fs 28.8mms 347.6 gramscms .09 mm/nB/L 16.95vas 29.926 Lsd 490.87 cm^2spl 85.3
