Posted May 2, 200619 yr Would a us amps usa-200 be a good amp to run a single 12" Rlp? I've heard the amp puts out 600+ at 2 ohms......assuming the rating is correct (or underrated as most us amps tend to be) it sounds to be a great match. Anyone have any thoguhts?
May 2, 200619 yr just one...that would be a sick combo!sealed...1.25ft^3ported..2ft^3 tuned to 34hz, 25in^2 of port minimum, or i fyou prefer the sick lowlows.....2.5ft^3 tuned to 28hz, 35in^2 of port.that second ported box is shaking the trailblazer to death with it's rl-p..lol...wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
May 2, 200619 yr Author yeah, deifnately just one, its only a king cab nissan frontier.....I was originally going to do a downfiring box but I may just have to try something else and squeeze in a bigger box......
May 2, 200619 yr Admin I'm going to be running my single dual 2 12" Rl-p off of the Xterminator in my sig.
May 3, 200619 yr Author Well then its settled, I'm going to go this route and figure out a box......NowI just have to find a usa-200.......
May 3, 200619 yr Author Ok, while im on the subject of the box.....Would you guys suggest using round (aeroports, or pvc) or going with a slot port and using more port area?
May 4, 200619 yr either..your preference.but if you go round, definitely go aeroport.wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
May 4, 200619 yr Author 2 options I came up with, I'm liking the second one better just because the box is a bit smaller. Obviously before any kind of bracing is added.... Edited May 4, 200619 yr by Jester1318
May 4, 200619 yr Make that slotted port go down the back of the enclosure... way too many bends in that port, and will lose alot of velocity.
May 4, 200619 yr Author Thats what I thought too, but wasnt sure if it would fit in the box..... I'll change the pic of it redone and see if thats better
