Here we go, starting the lightweight, simple install in the Miata biggrin.png
First off some pictures of the car, keep in mind I was always too busy enjoying driving it to do anything else, like cleaning it laugh.png
Just after a wash, comparing it with a friend's Z3.
1387930_655564761144159_909506377_n.jpg?
1376889_655564757810826_428131507_n.jpg?
Mock-up of the 7" tablet. Fits great in the scene
Target for the entire system is under 30 lbs. That includes wiring, fiberglass, minimal deadening, speakers, amp, tablet and miniDSP.
  • 2 weeks later...
  • Replies 75
  • Views 9k
  • The L-shaped metal is bolted to the case and another metal piece bolts to that to hold the plugs in place.    Wires soldered directly to where the buttons were. Tested and working fine   Hoping I ca
  • Some pics of the final tablet install look:       Still completely stock Nexus 7, I never shut if off, it just sleeps, battery never goes under 70% unless I forget to hit pause when I turn off the c
  • I'll have to fabricate some sort of amp rack to keep the amp in place. Couldn't find a better place to put it. very short power wires FTW!   It's TINY!   1 Extremis weighs in at 1.5 kg. So total wei
  • Admin
Naming rights!
So what's up with the Dracula references? What's that mean?
Where he lives.
Ohh he lives in Transylvania lol I was wondering why all the Dracula jokes!
Hah, yeah, I live in the land of vampires. And I've visited the "official" castle. Pretty nice crib :lol:
No subs, the Extremis should do fine. After selling my tablet, I'm getting it back and the PPI 900.4 should be here before Christmas. miniDSP can wait, the PPI has some processing.
  • 2 weeks later...
The amp weighs 2.5 Kg.
Pics!!!
It's TINY!
1 Extremis weighs in at 1.5 kg. So total weight with 2 Extremis and the amp is 5.5 kg. Dropping the target weight to 10 kg (22lbs). So still 4.5 kg to spare for deadening, tweeters, wiring, mdf rings, tablet and minidsp.
Really like my 900.4's small enough to install in a glove box of some cars and put out respectable amounts of power and sound clean doing it.
Started the amp rack cardboard mockup. It will be built it out of 1/16" thick flat stock, with speed holes to keep the weight down.
Going to use the battery hold-down bolt for one of the supports since it's convenient.
Yesterday I broke down and ordered a Nexus 7 (2012 model) :D
permanent mount for the tablet or making a dock?
I was thinking about modifying this dock (or using pins) for a dock set up
http://www.amazon.com/gp/product/B009UQZPA0/ref=s9_hps_ft_g147_ir01?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-3&pf_rd_r=1EQF9EDV8JRP95JWD4XX&pf_rd_t=1401&pf_rd_p=1705902322&pf_rd_i=1001023771
Tough to fit a dock, I'll mount it "permanently" and just run wires with plugs. One big problem is the volume control, if I don't have access to the rocker switch, the volume control will have to be somewhere on the screen. Some tablets have it there. And I will have to figure out a way to access the power button.
minidsp has a volume pot.
for power im guessing there's a way to boot when vehicle is turned on.
i started a mount but scrapped my plans. buying a new car this month
http://i277.photobucket.com/albums/kk69/killwish/photobucket-29702-1376162086652_zps2b8dd230.jpg
Edited by lithium
I want to keep it on all the time and just have it turn on the screen smile.png
miniDSP sure has one but first iteration of the system will be using the PPI's on-board processing. So I'll have to figure out a way to control volume.
Mounting it nicely is going to be a pain in the butt :(
the battery life is pretty solid so I bet it would hold charge for several days maybe over a week.
the ppi unit looks pretty good, i went the cheaper route with two 2x4 units.  maybe you'll be able to do some external volume control with a rooted os. iirc sean found a way to do steering wheel controls which would include volume i would think...
edit" mount idea
http://www.diymobileaudio.com/forum/build-logs-project-install-gallery/157938-2013-wrx-nexus-7-install-no-hu.html
Edited by lithium
Are there steering wheel controls? If so, it is easy enough to get them to talk with the Nexus. Or perhaps any other button in your car.
Can also root it with Timur's kernel so a volume control is in your task bar at all times. Just + - but it is enough.
Power control on that unit is EASY to reach if you pull the rear cover and can then make your own. Or use the kernel above to automatically unsleep when it see's power. Usually about a 2 second boot from sleep. Battery lasts about 10+ days with the car off in standby as well. As long as you drive once a week you'll have instant startup nearly.
And definitely permanent mount.
SDR Touch and some adapters will let you get free FM over your car's antenna.
If you want peripherals, before you go buy some let me know as I may go a different route and am all set up to do it. I just have WAY more screen real estate space than the 7 so I'd like to go bigger. ONLY the Nexus 7 (2012) can boot instantly via rom, charge over USB & use a USB hub all at the same time....unless someone has hacked something else in the past two months which I don't think.
Being the outside of the screen is flat and style of mount that sandwiches will work. Would have been the easiest screen mount in a cayenne. 1 piece of wood, routed, then cut and 4 holes drilled and stock mounts would have worked.
With the current kernel, in developer mode I could set it to never sleep when charging. And it goes to sleep 15 seconds after I stop the charge, so all is well on that side.
From what I could find, the volume and power buttons are on a separate PCB, connected through a ribbon cable. If I take it apart I can move it where I want and problem solved.
For permanent mount I need to figure out a cover to go over it, with magnets, so that everything is stealthy. Keep in mind it's a rag-top and a tablet in the dash screams steal me. A black plastic cover with the Mazda logo screams boring smile.png
Please let me know what peripheral setup you have, if you're selling, I'm buying. Not sure I want FM (antenna mast is broken and I'm not spending $50 to replace it at this point). But charge over USB and using a USB hub is mandatory. Plus I need to find a cable with a 90 degree plug.
People on head-fi were dicking around complaining that the DAC is crappy and there is a tutorial for using a USB DAC, did you ever get to listen to the headphone output?
In other words, progress on the amp rack...hooray speed holes :D
I ran out of gas for the MIG some time ago, so no welds until I can get gas :(
In the meantime I can finish off all the pieces and build an mdf amp mock-up to keep things in place when welding.
  • Admin
Nice work.
