Posted December 11, 201312 yr Hey there guys i just had a quick question. Right now in my car i have a ssa zcon 15' d2 running off a sundown 2500@1ohm. I just wanted to know if its possible to run the zcon off the sundown @4ohms since the efficency is better and i am happy with 600rms since i will be buying a new car and i want less power but keeping the same equipment since i dont wanna sell/rebuy etc.
December 11, 201312 yr Author Thanks a lot! I guess i'll be doing that and can i still use my 0 gauge even if its af 4ohm? Or get some 4 gauge wiring?
December 11, 201312 yr No keep everything the same. Just wire the sub to make it 4 ohms. Follow http://www.the12volt.com/caraudio/woofer_configurationsm.asp and it'll show you how to wire to 4 ohms.
December 11, 201312 yr Your wire size has nothing to do with the final load of your sub. If your amp takes 0 then use it no matter what. Bassink beat me to it.. :thumbsup: Edited December 11, 201312 yr by nadcicle
December 11, 201312 yr Your wire size has nothing to do with the final load of your sub. If your amp takes 0 then use it no matter what. Bassink beat me to it.. :thumbsup:Haha beat ya by less than a minute
