February 16, 201412 yr Author Wow! nice collection and good start!!!!Thanks Sencheezy! Im hoping In the end I can get it looking as clean as I can, I have a habit of rushing things unfortunately.. Ill post some pictures of the trunk this week, I bought some more wire so that all the wire in the back matches.Once I get that all switched out, the wire will come through the amp board to zed, so that side will look pretty clean.I haven't worked on the wall as I bought some new pieces for my other hobby and have to wait till my next check to buy the rest of my supplies for the wall.Although I will at least canter and bolt down the back and bottom plate.If I get enough back in taxes in the next few weeks, and/or I get paid for the bronco wreck Ill be buying an NS1.That's about all the updates I have atm.
February 17, 201412 yr Author That SP4 basket is just out of control. I need one in my hands.Do It, One of the flattest yet also loudest sounding subwoofers Ive heard. The Zcons seem very peaky in comparison. Although they have that upper end sting that some go for.
February 17, 201412 yr The subs and amp rack looks great. I'm confused a little on why you bypassed the factory head unit with an 80prs though. Why wouldn't you use an 8 channel DSP? Your driver choices don't thrill me but the installation looks good. Can't say I'd put a hole in my dash for a single din if I didn't have to but good luck
February 17, 201412 yr Btw for the SSA fans here Ill be putting 2 Zcon 18s in here shortly after the box is finished just as a comparison to the Sp4s. Ill try to make a video of both for reference when that happens.Nice subs you got there!
February 18, 201412 yr Author The subs and amp rack looks great. I'm confused a little on why you bypassed the factory head unit with an 80prs though. Why wouldn't you use an 8 channel DSP? Your driver choices don't thrill me but the installation looks good. Can't say I'd put a hole in my dash for a single din if I didn't have to but good luckFirst of all thanks, they look a lot better with plasti now. Second, I have always loved the 80prs and especially controlling the crossovers and such from the head unit.Not to mention I only have to buy one part to return to factory, I did as little damage as possible. The tweets I'm quite happy with, but the mid drivers are up in the air atm. I like the aurum cantus midwoofers, good quality but I think there are better choices for my build.Right now I've got my eye on the Sundown neo pro 10s.
February 18, 201412 yr Btw for the SSA fans here Ill be putting 2 Zcon 18s in here shortly after the box is finished just as a comparison to the Sp4s. Ill try to make a video of both for reference when that happens.Nice subs you got there! Agree!
February 20, 201412 yr Author Btw for the SSA fans here Ill be putting 2 Zcon 18s in here shortly after the box is finished just as a comparison to the Sp4s. Ill try to make a video of both for reference when that happens.Nice subs you got there! Agree!Thanks guys, The Zcons are not mine. A good friends but I have them for awhile as their house burned down and he has no where to store them safely. They still smell like smoke actually.
February 23, 201412 yr Author Going to drill holes for the leviathan speaker wires, but otherwise that's how it came out.
April 2, 201412 yr Author Box turned out a little smaller then I wanted because of the port being double baffled, and more displacements then I anticipated. Its about 6.4 cubes per woofer, 5.5 cubes for the port, tuned to 30hz.All that's left to cut is the front baffle, which will be double baffled as well with a flush mounted holes for the woofers.It took about 7 sheets of wood for all this.
April 2, 201412 yr Author Looks great!VERY COOL. Just saw this thread. Subscribed.Thanks guys, Its getting there I'm hoping with the smaller airspace for the subs I can get a real musical response out of them. Edited April 2, 201412 yr by SacredTanakh
April 4, 201412 yr Author worked from 10am yesterday to 12am today and got it playing. Its extremely loud, but it doesn't play the lows as well as I had hoped. I think once its sealed off a bit more it will get better, plus one of the woofers hasn't been broken in. So far I'm pretty happy with it, but now I need sound deadener for sure. Edited April 4, 201412 yr by SacredTanakh
April 4, 201412 yr Author Looks good!! What's gonna be the finish?Thanks Port is going to be painted white. I have some black leather that matches my interior fairly well for the front, and I don't think I have enough leather to do the sides too. So probably black carpet on the side beauty panels.
April 4, 201412 yr Just port that faital 8 you have in the door. Probably around 70hz or so....just a guess but knowing exactly which would help.
