Some of you may know me from the forums or facebook. Long time bass head and  have been into audio for 14 years.I do a little glass work and custom enclosures. I'm about to be in my 4th season of MECA, 2nd year with our own trunk classes(finally). I don't really post build logs as nothing stays the same long enough to be post worthy. But i figured id share a little of the last few years.
Sbn 13 was the last show i ran the Maxima at, broke the first Trunk class 150 at 36hz. Was alot left in the build and car in general. Unfortunately it was instantly scrutinized  due to the rear seat being non folding, a removable plate that sat behind the rear seat may or may not have become a issue at finals so i didnt want to risk it. Sold the car a few months later and bought a 03 impala to build from scratch.
294594_338553316236294_1776222100_n_zpsf
400378_2574794695287_1292548417_n_zps35f
1146975_10201379754961968_1481176866_o_z
1506996_10201379755201974_485826527_n_zp
522479_4553830409943_1836774117_n_zps8a9
First build didnt go to well. Ran with zero deadner. Electrical consists of  a Dc 275xp, one set of 4/0 runs, and 6 banks of caps. Lost one amp before the first burp,2nd time ever running them and it was a huge disappointment. Ran a single 500.1 and it clipped under load like crazy, was never able to get anything out of the single 12 setup so i started fresh
1005621_10200233860315318_323361936_n_zp
1000821_10200278156382692_612282678_n_zp
1146540_10200400394798576_98433145_n_zps
1157609_10200426754897562_1855026891_n_z
2nd go around i foamed out the trunk, and used 2 bulk packs of stinger roadkill expert. And decided to run a tried and true design. Used a single vfl-comp 15, on a pair of apk-3500s at 1 ohm each then dropped one down to .5. Did decently well, 48s at the headrest at 31hz
1545846_10201379725241225_191719657_n_zp
1525359_10201379724321202_1742170356_n_z
484791_10201379724561208_1825338965_n_zp
Did alot of squeezing a few days before world finals to get everything fitted. Road to Alabama, wired up at the hotel parking lot and road over to the Von Center to start testing. With all the trimming and modding to make everything fit i suffered a huge loss and raise in peak frequency. We were able to slid the box back forward an inch and it dropped the peak back down 3 hz and started back gaining. Just to let you know how low we started out it was having trouble breaking a 46 sad.png We woke up the next day scoped the amps and dropped down to 1 wired to .5 and started in testing. we got her up to a 50.6. Strapped both amps wired down and had trouble keeping the amps on. After about 30 burps we thought we had it nailed. Let the care cool a few hours before our final runs and never took in account for a cold coil. Amps shut down with no time in the lanes to reset. Was a tough pill to swallow. Was aiming for high 52s but didnt pull it off.
1507549_10201379723721187_1344434752_n_z
1017154_10201379724001194_1773143606_n_z
So here is the present. Shelling out the trunk for a 4th order now for a pair of Ethos 15s. If the space cant be pulled off ill build something simular to last seasons build. Not like it had any issues playing low. Tuned to 36hz, played down to 27hz and peaked at 31 and 49 relatively flat
1526615_10201376985572735_1590107898_n_z
1396785_10152046901963900_971662113_o_zp
Edited by 97maxima
Tuned in to whats next, I enjoyed all the pictures. Good luck in reaching your goals :fing34:
Tuned in to whats next, I enjoyed all the pictures. Good luck in reaching your goals fing34.gif
Thanks, undecided on a amp atm for the ethos 15s. Have lots to do, more deadner, a little sq front-stage and hopefully some good numbers.
For the 4th order bandpass ethos?
Good luck man! I'm excited to see some more ethos builds.
Yes sir!
Yes sir!
Nice! I'm getting some ethos soon too. I just need to figure out if 15s will fit, if not then definitely some 12s
Good choice in subs. Can't wait to hear your thoughts on them.
Yes sir!
from my understanding they like a small box
Yes sir!
Yea they do! Quentin had designed them to work well in small boxes.
Have you checked this out?
http://www.soundsolutionsaudio.com/forum/topic/59904-ethos-bandpass-option/?hl=%2Bethos+%2Bbandpass
Yes sir!
I had looked into the option for a strictly BP option but found it was needed after final large signal Klippel testing. The stock spider pack does well in ~3.5 total cft with a passband of ~ 25-75 hz
Yes sir!
Is that was supposed to be a wasn't?
Samples were built and Klippeled however at large signal there wasn't enough shift in parameters from stock format to offer it.
Ok because stock specs look perfect for a 4th the way they are :)
Building a more spl oriented enclosure for the 15s. After its done ill move on to a 6 cube street box
1519851_10201424660004566_1311414970_o_z
1489194_10201424657044492_2026754882_n_z
1538786_10201424660964590_1212988672_n_z
1601132_10201424660684583_1072589308_n_z
1525085_10201424660204571_1110168785_n_z
Nice!! What's the specs on the box? It looks great!
Thanks. its about 4 cubes tuned to about 37hz
looking good.... glad to see such a good builder on the team!
NICE LOOKING BOX!
Thanks!
A little more progress. Soon ill finish sand and resin then on to the outer flare and the inner/mounting flare.
995036_10201430856319470_1758604706_n_zp
7550_10201430857239493_601646795_n_zps70
shipping containers for a workshop?
Lol looks that way but its just some funky siding
I've been wanting to get my hand on a couple to make some hunting camps.  Boxing is looking great by the way.  As of two days ago I had 14 drivers in build que.  Yours should be going out soon.  I'll email your tracking as soon as they go out.
They would def have some uses.Thanks trying to get it together
