Posted January 10, 201412 yr Some of you may know me from the forums or facebook. Long time bass head and have been into audio for 14 years.I do a little glass work and custom enclosures. I'm about to be in my 4th season of MECA, 2nd year with our own trunk classes(finally). I don't really post build logs as nothing stays the same long enough to be post worthy. But i figured id share a little of the last few years. Sbn 13 was the last show i ran the Maxima at, broke the first Trunk class 150 at 36hz. Was alot left in the build and car in general. Unfortunately it was instantly scrutinized due to the rear seat being non folding, a removable plate that sat behind the rear seat may or may not have become a issue at finals so i didnt want to risk it. Sold the car a few months later and bought a 03 impala to build from scratch. First build didnt go to well. Ran with zero deadner. Electrical consists of a Dc 275xp, one set of 4/0 runs, and 6 banks of caps. Lost one amp before the first burp,2nd time ever running them and it was a huge disappointment. Ran a single 500.1 and it clipped under load like crazy, was never able to get anything out of the single 12 setup so i started fresh 2nd go around i foamed out the trunk, and used 2 bulk packs of stinger roadkill expert. And decided to run a tried and true design. Used a single vfl-comp 15, on a pair of apk-3500s at 1 ohm each then dropped one down to .5. Did decently well, 48s at the headrest at 31hz Did alot of squeezing a few days before world finals to get everything fitted. Road to Alabama, wired up at the hotel parking lot and road over to the Von Center to start testing. With all the trimming and modding to make everything fit i suffered a huge loss and raise in peak frequency. We were able to slid the box back forward an inch and it dropped the peak back down 3 hz and started back gaining. Just to let you know how low we started out it was having trouble breaking a 46 We woke up the next day scoped the amps and dropped down to 1 wired to .5 and started in testing. we got her up to a 50.6. Strapped both amps wired down and had trouble keeping the amps on. After about 30 burps we thought we had it nailed. Let the care cool a few hours before our final runs and never took in account for a cold coil. Amps shut down with no time in the lanes to reset. Was a tough pill to swallow. Was aiming for high 52s but didnt pull it off. So here is the present. Shelling out the trunk for a 4th order now for a pair of Ethos 15s. If the space cant be pulled off ill build something simular to last seasons build. Not like it had any issues playing low. Tuned to 36hz, played down to 27hz and peaked at 31 and 49 relatively flat Edited January 10, 201412 yr by 97maxima
January 10, 201412 yr Tuned in to whats next, I enjoyed all the pictures. Good luck in reaching your goals
January 10, 201412 yr Author Tuned in to whats next, I enjoyed all the pictures. Good luck in reaching your goals Thanks, undecided on a amp atm for the ethos 15s. Have lots to do, more deadner, a little sq front-stage and hopefully some good numbers.
January 10, 201412 yr For the 4th order bandpass ethos?Good luck man! I'm excited to see some more ethos builds.
January 10, 201412 yr Author For the 4th order bandpass ethos?Good luck man! I'm excited to see some more ethos builds.Yes sir!
January 10, 201412 yr For the 4th order bandpass ethos?Good luck man! I'm excited to see some more ethos builds.Yes sir!Nice! I'm getting some ethos soon too. I just need to figure out if 15s will fit, if not then definitely some 12s
January 10, 201412 yr Author For the 4th order bandpass ethos?Good luck man! I'm excited to see some more ethos builds.Yes sir!Nice! I'm getting some ethos soon too. I just need to figure out if 15s will fit, if not then definitely some 12sfrom my understanding they like a small box
January 10, 201412 yr For the 4th order bandpass ethos?Good luck man! I'm excited to see some more ethos builds.Yes sir!Nice! I'm getting some ethos soon too. I just need to figure out if 15s will fit, if not then definitely some 12sfrom my understanding they like a small boxYea they do! Quentin had designed them to work well in small boxes.Have you checked this out?http://www.soundsolutionsaudio.com/forum/topic/59904-ethos-bandpass-option/?hl=%2Bethos+%2Bbandpass
January 10, 201412 yr For the 4th order bandpass ethos?Good luck man! I'm excited to see some more ethos builds.Yes sir!Nice! I'm getting some ethos soon too. I just need to figure out if 15s will fit, if not then definitely some 12sfrom my understanding they like a small boxYea they do! Quentin had designed them to work well in small boxes.Have you checked this out?http://www.soundsolutionsaudio.com/forum/topic/59904-ethos-bandpass-option/?hl=%2Bethos+%2BbandpassI had looked into the option for a strictly BP option but found it was needed after final large signal Klippel testing. The stock spider pack does well in ~3.5 total cft with a passband of ~ 25-75 hz
January 10, 201412 yr Author For the 4th order bandpass ethos?Good luck man! I'm excited to see some more ethos builds.Yes sir!Nice! I'm getting some ethos soon too. I just need to figure out if 15s will fit, if not then definitely some 12sfrom my understanding they like a small boxYea they do! Quentin had designed them to work well in small boxes.Have you checked this out?http://www.soundsolutionsaudio.com/forum/topic/59904-ethos-bandpass-option/?hl=%2Bethos+%2BbandpassI had looked into the option for a strictly BP option but found it was needed after final large signal Klippel testing. The stock spider pack does well in ~3.5 total cft with a passband of ~ 25-75 hzIs that was supposed to be a wasn't?
January 10, 201412 yr Samples were built and Klippeled however at large signal there wasn't enough shift in parameters from stock format to offer it.
January 10, 201412 yr Author Samples were built and Klippeled however at large signal there wasn't enough shift in parameters from stock format to offer it.Ok because stock specs look perfect for a 4th the way they are
January 17, 201412 yr Author Building a more spl oriented enclosure for the 15s. After its done ill move on to a 6 cube street box
January 17, 201412 yr Author Nice!! What's the specs on the box? It looks great!Thanks. its about 4 cubes tuned to about 37hz
January 18, 201412 yr Author Lookin goodThanks, hopefully ill button it up tomorrow and pour some resin
January 18, 201412 yr Author looking good.... glad to see such a good builder on the team! NICE LOOKING BOX!Thanks! A little more progress. Soon ill finish sand and resin then on to the outer flare and the inner/mounting flare.
January 18, 201412 yr Author shipping containers for a workshop?Lol looks that way but its just some funky siding
January 18, 201412 yr I've been wanting to get my hand on a couple to make some hunting camps. Boxing is looking great by the way. As of two days ago I had 14 drivers in build que. Yours should be going out soon. I'll email your tracking as soon as they go out.
January 18, 201412 yr Author I've been wanting to get my hand on a couple to make some hunting camps. Boxing is looking great by the way. As of two days ago I had 14 drivers in build que. Yours should be going out soon. I'll email your tracking as soon as they go out. They would def have some uses.Thanks trying to get it together
