Van...van...van
  • Replies 322
  • Views 39.6k
Not huge progress but got the Van over to the house, got all seats out, Big 3 is done, I drilled out a hole in the floor large enough to do 4-6 runs to the back down the road. For now there is two runs of 2/0 going to the back battery bank. This afternoon I will start on putting in the head unit, running RCA's and maybe speaker wire to the front. May go ahead and look at door panel options aswell. I have a few ideas but unsure what to run. Probably 2 10's per door and one super tweeter per door. Since this is mainly a SPL and demo vehicle for shows I'm not too concerned with quality mids and highs. I need loud and clear. I also need to think about amp and battery placement. This will be a push to get completed this week
Here is the victim, she will clean up good though. Atleast its not a Ugly van, LOL
7F67F6AA-C832-4592-9FF8-846F2F1399F8_zps
Just test fitting the enclosure
792FB72B-832E-40EF-9C35-E56D4F47719A_zps
DC237508-B75B-4B90-88BF-81A7E3DCC53C_zps
So much room behind the wall, This is why I decided to change up to the Van. lol
D02B2ABF-7B42-4E0F-81FE-737180063572_zps
Here is the crappy progress photos so far.
Cutting floor for the runs to back
81386949-EEA0-4615-9426-528F341D5392_zps
This looks like a good spot, sound deadner works great for a grommet, lol
1163D060-DC14-4821-A8A2-32738BB5B91C_zps
Just alittle 2/0 laying around, haha
6C47DC41-9E1B-4B93-A9B7-EF192F7C3ACF_zps
Heres the big b*tch thats going in there. 400lbs sexy birch
2DF43827-1771-4F4E-B78A-A684A6EBDE41_zps
Thats done
FDB0ADDB-9958-4143-99E4-E270691BFF08_zps
Alternator wire ran and a new Die hard Platinum gp34 up front
CC25BD7A-827C-45A5-B9B1-5ED0802B692F_zps
BCBE6972-BCEC-4831-9350-97A0654F595E_zps
Any suspension upgrades in the future?
I wana hear it either way!
Nice start, everything looks good.
Truck! Do the Truck!
The truck can get just as loud as the van. Obviously the van has more space, but we all know, more space equals more _____
We all have budgets, I would rather have him have a true daily system, and to look nice, more than a show day vehicle only. I would like to see a showing of the truck for the year, then, as time allows for next season, go all out for the numbers with the van.
I added a little extra unicorn milk to the 18's so it should wang pretty damn good
Well, the frame on the van is a unibody frame type setup and it sucks asshole. I will need a to have a long ground bar welded to it if I want a good mounting location. The truck on the other hand has a thick ass nice frame I can bolt to easily. I am also now having the mental issue that I will have a good bit of coin in this build and can only hear it when going to shows cause the fucking suspension surely wont hold the weight and the fuckin trans may take a shit when it tries to pull it all so no cruising around in this bish.
I am about ready to move back to the truck because its built to handle the weight and just take my time and figure it out. My business is so slammed right now I cant be stressed over this fuckin show this weekend. Sorry the build log is so fucked. Not gonna do any work tonight and think it all over good. Money is not a problem at all, just cant make a solid decision.............
Look at this beast :)8928BDA9-F50F-404F-80F6-612FFCC771D4_zps
Well I went ahead and my big girl panties on and started the truck. Lmao!! Got the interior pulled, cut some metal, drilled some holes, got the false floor built, tomorrow i should get a lot done as well. Should be playing by the weekend. Not the doors though, I have the sundown comps up front I will leave just to get through the first show.
Wow that amp is a beast. Can't wait to see what you have in store for the truck.
yay!  I was pulling for the truck too!
Man that amp how the guts look...can ssa order that amp since they have the 3800.1
Sneak peak not sealed off, lots left to do
Edited by swift
Nice, looks like that mirror won't last long.
Truck empty, back windows plastic dipped black
279F7EB8-761B-4A82-BB8A-E913ADD99708_zps
Holes cut for power, ground on pass side
AF4DC507-F88B-4B57-8286-A7932A04171F_zps
Baffle mocked up. Big Thanks for nadicle for coming over and helping cut on the old shell.
0F94C4BC-AFEE-4BE7-AB29-BB1A1F723805_zps
Had to add 3 inches to the bottom to make room for the new sub layout.
20DA9B1A-5462-4AD9-A23E-8EA0907EF0DE_zps
13A96CAC-79BA-4D04-9031-B5AF33782387_zps
Baffle bracing, its 2 3/4 boards thick but needed more. This should do fine
C81E836F-B324-4943-B3DB-A2405DB22030_zps
69A173C6-A44F-430E-93FC-E03C43634A7E_zps
Just a sample of over 150ft of 2/0 in the truck, will be over 250ft when complete
696A9B9E-7540-4775-B1C8-A8A5B276F3C2_zps
Shell is in and secure
F6514275-5443-475F-AAFE-9C423A780A7F_zps
11C59EF7-05D6-4C32-B9F4-F8B7ADC3549D_zps
Baffle in
B7ED2E5C-9AFD-4CA6-B911-2034D340A54B_zps
Edited by swift
Question for you sir, what is the width and height of your baffle (excluding the port & including it).
60 wide and 33 tall not including the port, the total height is 40 tall with
Swift, you really got this thing going fast. It really kills the lows and shows the Ethos potential. That Ampere amp was legit as hell too.
Yeah I wont post too much about it until I get it finished up. The truck is taken far more of a beating with these 4 than the 3 SP4's but its not showing on the meter, atleast not at the freq I guessed at when I did my run although it was enough to take 1st place in Mod3 yesterday. That will give me the 3X points I need. I have zero deadner in the truck and havent even started to seal anything and do any tuning.
Listening to it at maybe 1/2 volume (35 or so on the headunit) it seems to maybe peak in the lower 30's. Once its sealed off I would expect that to be accurate at higher volumes as well. Maybe later this week when I get more done we can get your meter over here and do some testing.The whole truck just doesnt know what to do when the lows hit right now. lmao... One thing is for sure, I will need serious battery power to run two of these amps!!!
