Posted January 15, 201412 yr i have a xs d3100r that keeps growing whitish greenish crystalized corosion on the negative brass battery post. whats up? is it leaking?
January 15, 201412 yr Probably bad, Had this happen to a buddies d3100 and XS kept calling it good but it wouldn't hold a charge. Sealed AGM batteries should not leak.
September 3, 201510 yr My xs power battery xp3000 has the same on negative post. White Crystal acid . But it holds voltage like a champ still. Anyone Els or anyone have any idea if that battery still usable
September 4, 201510 yr Xs power said it's ok battery, since voltage still holds 12.8+ . They said just clean it with water + baking soda + a brush or tooth brush.
September 4, 201510 yr Xs power said it's ok battery, since voltage still holds 12.8+ . They said just clean it with water + baking soda + a brush or tooth brush.Coca-Cola works just as good. Spray it down with some squirrel piss. Aka wd40 and ur good to go.
September 4, 201510 yr Xs power said it's ok battery, since voltage still holds 12.8+ . They said just clean it with water + baking soda + a brush or tooth brush.Coca-Cola works just as good. Spray it down with some squirrel piss. Aka wd40 and ur good to go.Lol squirrel piss . Thanks il try it
