Posted January 30, 201411 yr Ok I have an 06 Scion xB. Not much room in the back for a box. I currently have a Sundown Audio Nightshade v1 and a Sundown Audio 1500v1. I would like to change systems and hopefully get a little louder. I will be going with top of line equipment. IE Digital Designs, Sundown, or PSI. What is everyone's opinion on what I should go with?
January 30, 201411 yr what size sub?what is your electrical like? are you trying to replace sub and amp or one or the other? Edited January 30, 201411 yr by Heisenberg
January 30, 201411 yr Author I have a 12" Nightshade. And I would like to just change out the sub, not the amp. what size sub?what is your electrical like? are you trying to replace sub and amp or one or the other?
January 30, 201411 yr dss ethos. Fi-q, soundqubed HDC3 and 4, sundown X and zv4, Fi BL, Any of the SSA woofers
January 30, 201411 yr 10's or 12s. depending on your woofer choice. (different woofers want more or less airspace)
January 30, 201411 yr model them against your current woofer and box. otherwise you're just fucking around wasting money. figure out if you can fit a 15 or a pair of 12s. Edited January 30, 201411 yr by lithium
March 11, 201411 yr We have a 2011 Xb that has seen the likes of a single HDC412 (2,000RMS), to a wall of HDC315's (1.500RMS). There is more than enough room to run any of our woofers, though it's up to you to decide how much space you are willing to give up!Check out our Demo Install here: http://www.youtube.com/watch?v=4YM9y_rUlt4&list=UUiAFvyEqYBU36BOPwSn0ERA&feature=share&index=1
March 11, 201411 yr I come up with 4.4 cubes net. I would do two dss ethos 12". Best option imoThat would be 4.42 gross before sub/port/bracing/walls... Not a ton of room.But still a workable amount. How much airspace do the DSS ethos 12's need? I know Q has it posted in his thread on them. Should definitely check them out. Edited March 11, 201411 yr by nigel
March 11, 201411 yr I come up with 4.4 cubes net. I would do two dss ethos 12". Best option imoThat would be 4.42 gross before sub/port/bracing/walls... Not a ton of room.But still a workable amount. How much airspace do the DSS ethos 12's need? I know Q has it posted in his thread on them. Should definitely check them out.1.5 net per sub. Could be squeezed down to 1.25 Edited March 11, 201411 yr by Quentin Jarrell
