Posted March 8, 201412 yr Klippel testing was performed to verify BL linearity. Testing came out good but I'm gonna try a 12 layer coil before I proceed with production. The current coil is 8 layer flat aluminum with 50mm winding width. This coil will work fine with the current soft parts limiting the driver to ~35mm xmax which will take ~2,500 watts rms to hit. However when I get my new soft parts made allowing ~50mm - 55mm one way xmax it will need ~3,500 watts to reach xmax and I'm not comfortable using the current coil with that much power. Below is the BL curve. It is prematurely cut off due to hitting suspension limits. It should remain nearly constant to 37.5mm. Still with the current soft parts there is a loss of less than 10 percent BL to ~25mm. Below is coil offset. Extremely linear to 25mm sown by the red line. Below is suspension offset. Again extremely good Power compression displacement. again limited by suspension Inductance. Not too high but will be a bit higher with larger coil so faraday rings will be added. Again extremely linear. So far I am happy. It just needs a little tweaking.
March 8, 201412 yr Author For comparison below are BL curve, symmetry, and inductance curve of the Ethos 15. Although it is a good driver it still has the non linearity of a standard overhung driver. Compare the graphs to the Magnetar above.
March 10, 201412 yr Author What are the T/S ? Looks like a very linear driver.Really only tested to ensure BLx was linear. The top plate ID's on this sample is about 3mm too bigFS. 24Qts. .49Vas. 190 litersThese will change with the increase of BL but so far it's a good starting point. The final driver may use a 12 layer coil as it will need ~3.5-4k to reach ~50mm one way Xmax on the new soft parts I'm having engineered. I have someone testing it. If they don't burn it up I'll keep the 8 layer coil. The final driver will have faraday rings between the gaps on the pole and an aluminum pole sleeve.
March 10, 201412 yr Linearity, long throw, mid Q reasonably low Fs. That driver would do pretty damn sweet IB in a vehicle in an SQ install
March 10, 201412 yr Author Linearity, long throw, mid Q reasonably low Fs. That driver would do pretty damn sweet IB in a vehicle in an SQ install If it didn't weigh 85 lbs.
March 13, 201412 yr Linearity, long throw, mid Q reasonably low Fs. That driver would do pretty damn sweet IB in a vehicle in an SQ install If it didn't weigh 85 lbs. Goddamn. LOL
March 13, 201412 yr Author Some things are being addressed that won't be shown until production is ready for resale. The changes being made may shed a few pounds from it, maybe. I will say I am concentrating on making it as efficient as possible, keeping BL as high as possible through out the suspensions usable throw. Things I'm doing will...1) increase sensitivity2) increase cooling3) reduce motor noise by addressing superposition (google it. Not going into detail)This will be the best possible high output driver I can make using a 3" coil and the current soft parts avaliable. It should need around 2,500 watts to reach 35mm one way. In recommended boxes.
March 13, 201412 yr I have the feeling their is going to be a flood of Used Ethos for sale in about 5 months then, Wanna go ahead and start me a lay a way for 2 of these now? J/K! *Unless you want to, then I am serious. EDIT:- just saw the no presale post. Edited March 13, 201412 yr by Leedogg
March 13, 201412 yr Author Nope no presaleOhh what's the price looking to be?Not sure. Somewhere between 500 and 1000
