Love the voltage meter location.
  • Replies 236
  • Views 23.6k
  • smashedz28
    smashedz28
    Why the hell does everyone want to fill their doors up with such crap? 4 super tweeters, really? Maybe I'm getting old :\
  • antoinez28
    antoinez28
    Will I sold the HCCA 15.2's and sent my bc2000's to db-r great service should be getting the amps back sometime next week. Than I going to redo the sub box to fit the 2-18" ethos that I should be gett
  • Monkey see monkey do. Even if it's just slinging poop
Thank I did it because I have not seen them there yet...thanks
I would have to lean way forward to see them in my truck. Your headliner must be different. Do you have a sunroof? Looks pretty slick so far. Are you running just the under hood battery right now? Curious to see what kind of voltage drop occurs with two bc2000s as I am considering a bc 3500 myself.
Volt drop is crazy. I'm only running one do to the fact that I only have one ethos but my
Thanks a lot swift...for the come up pics coming soon sub-stage should be what I had in mind at the end of the week
23e77e28a5fff70aab5530b265369e94_zps92cbbe here Thursday
great install man. Overkill everywhere !!
Lol...thanks
Both 18s are here all hooked up but not sounding right should I use y spilters or wat... It plays louder with one hooked up... But there not cross
Are you wiring them out of phase?
Y splitters for what, please explain more in detail about your problem and setup so people can actually help you.
Go over all your wiring even if you think its right, pull out subs and check even if you think its right. Have you done any troubleshooting so far, if so what did you do and the result.
At work...12s....
9a416b3be603a7873a36dea90137a0f6_zps1e13 more to come....found the problem the input switch was on the slave switch something like that....get into more detail once I'm off work...need to find out how to upload vids on here
Glad you found the issue.
Upload vids to youtube, then link or embed here.
Ok will do
Thanks once I get the subs out than put them back in I will upload a pic
So here how my amps are set 4de318d08ad74b545b2767cdbefef75f_zps899athat the first amp
c2cb2b21a6986c9b4e5517b527fec772_zps27c0 and the second amp I think I have it all wired up right gains are the same maybe I need to get second opinion on how I have it vid coming once I learn how to take it off youtube
Looks like you need your ssf and lpf turned up some
The only thing I turn up is the gain...but I will tur
will do and I'm going to get it meter at this comp that's coming up next weekend
Any good hair tricks songs and or spl songs that you guys play at comp you go to
Good stuff
I can say this i love my subs...and will be buying one more...everybody I drive up on loves them too thanks great product
where should they be set at
