This will be my first post on this forum. i am building a c pillar wall in my 2010 scion xb rs. I am starting this thread pretty late in the build so it will completed very quickly. any advice would be awesome. i have been building systems for a few years now but it is my first wall and first time using 18s.
Equipment will be;
2 incriminator audio Judge 18s
sundown NS1
mechman 240 amp alt
crescendo logice group 31 batteries
audiotechnix 1/0
sky high 8 guage speaker wire
rockford 2 channel for mids
2 sound qubed 6.5s (temp)
  • Replies 263
  • Views 28.8k
  • Sencheezy
    Sencheezy
    That fur only takes away pressure... But I guess it'll look cool on SMD and youtube.
  • so this is just an idea at the moment but since im going to be rebuilding the system i was considering adding in a third 18. any thoughts on this??? and also any suggestions on an amp to power all thr
  • You mean IA, 32hz should be fine.
Sounds like it's gonna be a badass build!
Welcome to SSA btw
cant figure out how to post pictures... this is why im a noob
Can someone explain how. sorry for the beginner question
I use a host photobucket to upload my pics and then copy and past them here.
thank you!
thank you!
Your welcome :)
the beasts. 88 lbs per woofer!!!Screenshot_2014-05-16-14-57-45-Copy_zps4
I have more pictures on the way after i get off work. funding this whole project with serving tables-_-
I know how you feel, all my builds are just funded by helping with other peoples builds lol
nice man. nice shoes too.
Been waiting for someone to do a build with those. They look like monster subs for sure
same here. i havnt seen anyone build with them yet. they look even better in person
Screenshot_2014-05-16-14-58-42_zpsd31936
Awesome design scion... rivet in the stock speakers so nothing else will fit in. built these adapter rings to fit the 6.5s
Screenshot_2014-05-16-14-58-37_zps0f4cf1
soundqubed's mounted
Screenshot_2014-05-16-14-58-35_zps7422e0
these are only temporary but for the price they sound amazing. only 56 bucks for 2 of them
Forgot to mention that i used second skin pro throughout the car. i didnt have any good pictures of it being installed. used 2 bulk packs for the whole car.
Damp Pro is great stuff, but damn if it isn't hard to shape when it's not hot outside. I have the 18" Death Row, so I'm definitely curious to see what you end up thinking of the Judges. Just don't forget to weatherproof those speaker rings before you close up the whole build.
Screenshot_2014-05-16-14-58-26_zps8a03fd
bottom of the box not bolted down yet. il get a better shot of the batteries when its light out tomorrow
I deffinately found that out the hard way. i did the roof when it was 80 out and it wasnt bad but i did the doors when it was about 45-50. midwest weather is crazy like that. and thanks for the tip
Screenshot_2014-05-16-14-58-24_zps35c136
double layering everything. i might go back and tripple the baffle if it needs to be done
after port and sub displacement the box is 12.5 cubes. would have liked for it to be a little bigger but didnt have the room. about 15.5 qubes before port and sub displacement. ported to 31ish hz for music mostly
Damn I bet that bitch is heavy!!
Nice build man, Im tuned in.
Edited by khinds94
Screenshot_2014-05-16-14-58-15_zpse57165
first layer of the baffle cut out. not bad for a homemade circle jig made out of a scrap piece of mdf
already finished the second layer and glued them together but the only pic of that turned out blury
