Screenshot_2014-05-19-18-14-40_zpsd1d658
  • Replies 263
  • Views 32.1k
  • Sencheezy
    Sencheezy
    That fur only takes away pressure... But I guess it'll look cool on SMD and youtube.
  • so this is just an idea at the moment but since im going to be rebuilding the system i was considering adding in a third 18. any thoughts on this??? and also any suggestions on an amp to power all thr
  • You mean IA, 32hz should be fine.
Screenshot_2014-05-19-18-14-29_zpsbe3aac
them magnets though
Screenshot_2014-05-19-18-14-32_zps628e7e
very creative in how you mounted those heavy beasts :fing34:
that poor lil car.LOL  Gonna pound the bolts out of it.
Looks very nice man!!!
J
nice job!
Question
I noticed you're laying the batts down in the second row footing area. If you were gonna do this, why didn't you just wall it at the b pilar?
nice job!
Question
thank you. and as far as positioning of the wall. original plan was going to attempt to keep the back seats with no foot room which half way through this build didnt work out. i had already designed the box for the c pillar and just wanted to try it out. i have it set up to where i can move the entire box forward if i decide to seal it off at the b pillar. plus no i am planning on running an air suspension set up and want to try and mount the compressor and air tank next to the amp which will be on a false floor above the batteries. i might change this though eventually.
thank you!
thats the plan lol
J
thanks man!
Screenshot_2014-05-20-11-34-04_zpsbb3e22
finally got the back bolted down. because of the weight of the subs i had to make to back of the box removable in case something goes wrong with the subs. u used half inch thick rubber to seal off the back and it is air tight.
Screenshot_2014-05-20-11-34-15_zps553c4c
cones got a little dusty but heres what its looking like as of right now. the vinyl got a little messed up but that will all be replaced with purple and blue shag fabric stuff to match the car. still need to seal the wires into the back of the box
i know my wiring is a complete mess right now but i still have a lot of work to do. im going to build a false floor for the amp to sit on that will cover up the batteries and wiring. just have to find a way to get more wood to my house. im going to try and use something a little lighter than the mdf because of all the weight added to the car already. il be building the trim pannels at the same time. im not sure when il be able to get wood though as i have zero friends and do not poses a pick up truck. so it could be a couple days until one of my brothers friends can help me
Screenshot_2014-05-20-11-33-54_zps6ca6d2
you can see in this picture how bad the car is sagging in the back. about 1 and a half inches and the car is already on lowering springs... i have decided to use the money for my other car projects to buy a full air suspension setup. might as well go all out. If anyone is running air suspension i am open to any suggestions on brands and anything else. i have never done air suspension
Just got the amp tuned off my dd1 and did some initial testing on about a quarter power until i get the speaker wires sealed in... and HOLY SHIT!! these are insane. barely moving and they were crazy loud. il post a video later when i get home and find somewhere to play it on half volume since the subs are not broken in at all yet
Your senses will be ALOT better than using that dd1. . Be careful
It will sound MUCH different when its sealed off from the rear.
thanks for the tip. i just mainly use the dd1 for my mids and highs
Edited by icluphf
Looks like its going to be LOUD! Nice job so far
thanks!!
alright. i got the new covering material for the box. going to build some trim panels today and tomorrow with all the scarp mdf i have. still waiting on a sheet of half inch birch for the false floor covering the batteries and all the wiring. i will hopefully get that in the next couple days.
also probably getting new rims soon. not to big since the car is going to be bagged and slammed. im open to any suggestions for the wheeles on the car. sizes 16-18 inch probably
Screenshot_2014-05-21-11-59-49_zps509cce
this might get some hate but this is what im recovering the box in
Screenshot_2014-05-21-15-03-20_zps71da3c
getting some cardboard templates started for the panels to seal the box off
Screenshot_2014-05-21-15-03-09_zps14f065
hears what they ended up looking like. have to go to work now. il try to get the back of the car sealed off tomorrow if possible. and hopefully get the wood for my false floor soon.
That shag is going to be moving like crazy lol. mite look pretty cool . . . . Trim panels are looking good so far
