Posted May 18, 201411 yr Figured I would give y'all something to look at. This build is for my little brother in his 95 Burb. Head unit... pioneer deh7500hadAmps... Two bc2k's on subs, CT sound 125.4 on mids and highsSubs... Two Sundown X18's Box.... 14cu tuned at 30hz... 207sq in of portSubs up port to side, cause I want to.....Front stage.... Sundown Neo-Pro 8's, Nendo FT1's on dash pillar pods. Electrical.... Big 3 with all 2/0, two Die Hard Platinums gr34's underHoodPics to follow.
May 19, 201411 yr Author Here we go. Long day but its done for now. Got to dye the vinyl door pods, make a beauty panel to cover amps, add second amp and several more batteries. Its loud and sounds great, well when you hold the side window now. After the first song the window mold, sealant gave way and now the side window flexes out a inch when bass hits. Not sure what to do other than to call a window guy to come take it off and reseal... My brother got this truck cheap and the person before really trashed the carpet so i pulled it, pressure washed it, re dyed it grey and now it looks 10x better. BeforeAfter Now shes empty and getting wired Tweeter placement in corners and pods dyed to match as good as possible Sears had a big sale so I got him a g34 for under hood and me a couple g31's for my build CT sounds 125.4 (sounds great and making good power), Neo Pro 8's (these sound much better than the Crscendo 8"s BTW. My old box from my truck was used, which Im glad because my arm is still fucked and abig box build would have hurt. Also just glad someone could use it considering there is roughly 350-400 bucks in just material that was used for it. Its a big as a small fridge, lol
May 19, 201411 yr Author Lots going on under hood, Big 3 and adding the second battery. All 2/0 Coleman Royal stage cable used. Sundown X18's D2's. Subs are huge and very impressive looking The leather beauty panels where also dyed to match the interior and subs wired to .5, I kinda like the two tone look Amps mounted under rear seats. Just needs a beauty cover Doors done, the black leather pods will be dyed to match in a couple days, (I ran out).. Tweeters installed also Thats pretty much it for now. Check list is the window needs fixed, second 2k, batteries installed and door pods dyed to match. The truck is loud, how loud not sure on the single 2k, probably 46-47's. Hoping for 50's with the second amp. The front stage is just clear and as loud as you could ask for. But all in all a good build for his first big setup.
May 19, 201411 yr Sweet build, swift. Got a link to your original build with that box? Edited May 19, 201411 yr by bombsaway
May 19, 201411 yr Author Sweet build, swift. Got a link to your original build with that box?Yeah, it's on here somewhere. I will try to post it when I'm not mobile
