Posted May 20, 201412 yr im wanting to get the best output out of my zcon before I build a box. im going to be running it on a bc3500 @ 1 ohm. the electrical will be good. using a singer 250 and 6 yellowtops. what my question is should I go with a bigger box around 3.5-4 cubes or a slightly smaller one because of of the power around 2.5-3 cubes. both tuned in the low 30's? any input/help would be greatly appreciated
May 20, 201412 yr Author What size is the sub?lol damnit left that part out. its a 12. gonna be in the trunk of a cavalier
May 20, 201412 yr Admin With that power and that you are focused on output, it means you're probably going to be pushing that amp hard. So I would lean you towards the smaller range of the enclosure volume size.
May 20, 201412 yr With that power and that you are focused on output, it means you're probably going to be pushing that amp hard. So I would lean you towards the smaller range of the enclosure volume size.With this in mind would 2.75 net ft^3 be a good starting point, with 45in^2 of port area?
May 21, 201412 yr With that power and that you are focused on output, it means you're probably going to be pushing that amp hard. So I would lean you towards the smaller range of the enclosure volume size.With this in mind would 2.75 net ft^3 be a good starting point, with 45in^2 of port area?With how much power?
May 21, 201412 yr Author With that power and that you are focused on output, it means you're probably going to be pushing that amp hard. So I would lean you towards the smaller range of the enclosure volume size.With this in mind would 2.75 net ft^3 be a good starting point, with 45in^2 of port area?is somewhere in the middle really where you wanna be?
