Got a local shop who needed to make some room so I picked a few things up, but just don't need em so up here they go.
Phoenix Gold M44, MS-275
Zapco 360.4
A/D/S PH 15
M44
Into 4 ohms @ 12.5/14.4 VDC 40/55 WRMS x 4
Into 2 ohms @ 14.4 VDC 80 WRMS x 4
Bridged into 4 ohms @ 14.4 VDC 105 WRMS x 2
Frequency Response +/-1dB from 20Hz to 20kHz
Signal to Noise Ratio >100dB
Input Sensitivity 200 millivolts to 2 volts
Input Impedance >10k ohms
Input Voltage Range 10.5 volts to 15.0 volts
Typical current draw at idle 750 milliamps
Crossover Frequencies 30Hz to 600Hz
Crossover Slopes 12dB per Octave
Bass EQ 0 to + 12dB @ 45Hz
Minimum Impedance 2 ohm bridged/1ohm stereo
MS-275
Into 4 ohms @ 12.5 or 14.4 VDC 75/95 WRMS x 2
Into 2 ohms @ 14.4 VDC 125 WRMS x 2
Bridged into 4 ohms @ 14.4 VDC 280 WRMS x 1
360.4
Stereo, 4 ohms: 4 x 50 Watts
Stereo, 2 ohms: 4 x 90 Watts
Bridged, 2 ohms: 2 x 180 Watts
T.H.D. + Noise: <0.025% @ 4 ohms
PH15
50 x 6 @ 4ohm
75 x 6 @ 2 ohm
110 x 3 @ 4 ohm mono
Stable to 2 ohms
.05% THD at rated power
Overload and Thermal protection modes
105db S/N ratio
Descriptions/Condition of all items: :
The amps have had the cases properly cleaned up. The caps in the PG amps appear to be fresh and not leaking (common problem with these). Examined the boards and found no evidence of burned up parts, or other issues. The shop I picked them up from needed to clear out old inventory to make room and claimed that these all have been bench tested and work. My home bench testing unit is currently buried in my garage so I don't have an ability to independently test these amps, so they are being sold as-is. Gut shots can be taken if need be.
Unfortunately the M44 has some oxidation on the case and terminals along with some nicking on the silk screening.
The MS275 has been hard wired, so no terminals.
The A/D/S has no plus, and unfortunately i lack a thin bladed flat head to remove the wires already in the terminals. No low level plugs
The Zapco is in the best aesthetics of the group and is also lacking plugs.
Pics are in the next post.
Looking for 400 plus shipping for the lot.
J
Some quality equipment here. That ads keeps staring at me, but I have enough on my plate right now.
Good luck with the sale!
Appreciate it. Open to cash and trades as well.
J
Last day before I split them up. Offers will be considered.
J
Ok open to selling separately. Feel free to PM offers while I contemplate pricing.
J
Nice!! glws
Appreciate it.
I'll figure out prices tonight.
J
Would be sweet to have that A/D/S.  Used to be a favorite brand of mine before Directed screwed it up.  GLWS.
Appreciate it Aaron. Feel free to PM me if you want to see if we could strike a deal.
J
No solid interest so to ebay the lot goes.
J
Toss me an offer bro.
Got em up on ebay but the ads and zapco have no bids yet.
J
