Posted May 22, 200619 yr what is the ohm load thay will take. what kind of power do thay do.thanks clarence
May 22, 200619 yr They will take burps at below 1/4 ohm. The higher the voltage the higher the output. Depending on set up they will do from 1500-2000 watts.
May 23, 200619 yr Author im running it at .28ohm on music for bass race on 2x18xxx 1.4 omh per quad well the amps take it or not thanks clarence
May 25, 200619 yr I have two 1500DE's running two DD9515's in my dakota and they are insane loud. I have metered them on term lab at 153.7 consistently!! These amps are no joke. I have had many other amps in this rig because I am dealer of many brands and nothing has touched this so far, not even the big bad DD Z1.Richard
May 25, 200619 yr Admin I have two 1500DE's running two DD9515's in my dakota and they are insane loud. I have metered them on term lab at 153.7 consistently!! These amps are no joke. I have had many other amps in this rig because I am dealer of many brands and nothing has touched this so far, not even the big bad DD Z1.RichardPIX!!!
May 25, 200619 yr Here is a link to some pix of system before the switch. Now it has two 1500DE's and an AX600Tu. More to follow when I snap some new shots. The truck is out for paint now. http://www.termpro.com/asp/competitorstats...=52890&Season=0
