Posted September 10, 201411 yr Was thinking of ordering 10" Ethos was needing the physical dimension for these subs. Also needing recommended enclosure sizes for a ported enclosure.
September 10, 201411 yr Q will chime in at some point, but if I remember correctly he's waiting on klippel results. After they come in all the ts specs and dimensions should be on the website.
September 10, 201411 yr Author Well in want to order two or three depending on the outside diameter specs. I'm sure I can squeeze in three but to want to make sure. I don't want my enclosure to look like s*&t. The space in have is only 15" high x 45.625" wide.
September 10, 201411 yr Is the port going on the same plane (baffle) as the three subs? Subs OD shouldnt be more than 11", if you can fit that then you are golden.
September 10, 201411 yr Author I was hoping for the port to be above the baffles Edited September 10, 201411 yr by sumplikapimp78
September 10, 201411 yr If you have 15 inches in height do 12's. The box will be nearly the same size.
September 11, 201411 yr Author Wasn't trying to be that close to the 15. The 10's would seem more ideal. I'm sure I'll only run just 2 10's, the depth is most important.
