Need help with box demensions for a custom built subwoofer The RE has tc aluminum basket 4" 8 layer flatwound aluminum voice coil 3 10" tc spider pack with 1" spacer 8 gauge ofc direct leads dual 2 ohms voice coils everything is brand new just the moter is used also has a two tone carbon fiber dust cap can take 4000 watts rms
Thanks going in a astro van
Are those the only specs about that sub you can give us?
need ts parameters.
not enough info!!
We don't even know the size of the subwoofer...
need ts parameters.
He must be trolling
Can't build a box for a frankenwoofer without measuring the T/S parameters. If you haven't built it already you are WAY better off not as slapping a bunch of random stuff together never nets nice results.
Got the sub in a trade how would I get the t/s parameters
Did Re build the sub or was it built by some person using Re parts?
  • Admin
Thank you Google:
Specs:
Fs: 31.0 Hz
Re: 1.14Dvc
Qms : 4.14
Qes : .517
Qts: .46
Sd Cm2: 810
Vas: 87.7
BL: 12.14
SPL 1W/1M: 88.9
RMS: 2000W
The sub was built by zueslicious from ****
The sub was built by zueslicious from caco
Then get the t/s parameters from him if you don't think Aaron's are right.
Or you could do what ///M5 said and measure your own.
Have you tried calling RE Audio?
Edited by pmureika
Arron's are right but for a stock destroyer.
Aaron's are for the destroyer and what RE would have. Being this is a "Custom" woofer it won't match those. Could be WAY off in fact. All that being said, I've never seen a "custom" woofer really worth using. If the builder can't share T/S parameters then he is guessing which is not how I would want a woofer designed.
Well unless you know somebody that has  the equipment to measure them.
You need to get them from the guy that built it.
