Posted October 17, 201411 yr I have read a little bit up on XS batteries and Mechman alternators But on Mechmans webite, when i enter all my car info (Car brand-Nissan, Model-Altima, Year 2001. Nothing pops up) What are your opinions on what i should need to run Two Sundown SA-12 D4s on a Sundown SAZ-1500D v3 at 1ohm (1500watts) with 1/0 Xs flex wire?
October 17, 201411 yr Do big 3 wiring and get the biggest AGM battery you can fit under the hood. Buy a volt meter and monitor voltage, if droping more then you want than buy an AGM battery for the trunk area.
October 21, 201411 yr I'm guessing this is a 100 amp,I would suggest the big 3 with at least 0/1 100% oxygen free copper..No CCA garbage you can leave your factory wiring in place and this will not effect nothing at all...will work as a back up if your big 3 wiring was ever to get damaged..As it will travel in the path with the least resistance...I would suspect this will fix any voltage drops with your current set up....For future reference you could probably email mean green and they could rewind your factory alt to fit your needs...
October 31, 201411 yr Do big 3 wiring and get the biggest AGM battery you can fit under the hood. Buy a volt meter and monitor voltage, if droping more then you want than buy an AGM battery for the trunk area.That's what I would do ! It should work for the power you will use.
