Posted January 16, 201510 yr I'm going to be building a second enclosure for my Fi Bl 15. For my first enclosure I made it out of Birch Plywood so what I was wondering was if Cherry, walnut or poplar would be good for a box?
January 16, 201510 yr I'm talking Hardwood. I know poplar isint considered a hardwood thoughThe two best materials are mdf or baltic birch plywood. That would be my opinion. If you want you can build it out of any kind of wood. But a ply wood would be better then solid wood. I wouldn't recommend the other woods. Edited January 16, 201510 yr by pmureika
January 16, 201510 yr I'm talking Hardwood. I know poplar isint considered a hardwood thoughThe two best materials are mdf or baltic birch plywood. That would be my opinion. If you want you can build it out of any kind of wood.But a ply wood would be better then solid wood.I wouldn't recommend the other woods.Why wouldn't solid wood be a good choice? Acoustics, or cutting difficulties?
January 16, 201510 yr Prone to splitting/cracking I would think. Solid pieces tend to do this as they dry.Whereas with a ply, if one of the layers cracks/has voids it doesn't necessarily comprise the entire piece. ???
January 16, 201510 yr I built a few enclosures out of real hardwood , measure 10 times and cut oncebecause one bad cut can be expensive....LOL hardwood makes a nice looking enclosure but it has to be maintainedlike a piece of fine furniture .. oiled so it does not dry out Edited January 16, 201510 yr by Thumpper
January 16, 201510 yr Hardwood, besides not liking to be attached at more than one axis and cracking, has too many uncontrolled resonant modes to use as a loudspeaker enclosure material. Successful solid wood cabinets have used the butcher block approach to alleviate the two previously mentioned problems, look at Sonus Faber and you will see what I am talking about. Acoustically, MDF is the best choice of materials in this thread. High quality plywood is the strongest... So choose you poison...
January 16, 201510 yr Those Sonus Faber speakers are a pleasure to look at o.oWhile building materials are being brought up, is lexan/plexi an acoustically appropriate material for an enclosure, if it was the primary building material (not a window). /endthreadjack
January 16, 201510 yr that's one of the reasons why those expensive Frugal Horns have a nice looking hardwood faceplateand everything behind is either Baltic Birch or MDF personally I hate working with MDF because of the dust but it's the most acoustically deadand the reason why I use it the most
January 16, 201510 yr MDF dust is terrible... It also isn't supposed to be good for you over the long run... I know I have been breathing it for at least 20 years... MDF is cheap, also... We tend to forget that fact...
January 16, 201510 yr While building materials are being brought up, is lexan/plexi an acoustically appropriate material for an enclosure, if it was the primary building material (not a window)./endthreadjack I built some enclosures out of 1" acrylic (plexiglass) in the mid 90's for some Focal woofers in a car audio install. It seemed to sound fine, but is a lot of work, took forever, I ruined a ton of material and spent hours buffing out scratches... It was also expensive then, I can only imagine now...
January 16, 201510 yr While building materials are being brought up, is lexan/plexi an acoustically appropriate material for an enclosure, if it was the primary building material (not a window)./endthreadjackI built some enclosures out of 1" acrylic (plexiglass) in the mid 90's for some Focal woofers in a car audio install. It seemed to sound fine, but is a lot of work, took forever, I ruined a ton of material and spent hours buffing out scratches... It was also expensive then, I can only imagine now...I really really want to swap my basket out for a TI on my btl when I eventually recone it, would you mind if I messaged you about the details of building a plexi box when I do so?
January 16, 201510 yr I made a few enclosures with both Lexan and Plexi the Lexan flexes/vibarates if used for large windows or panels and makes noise, it can not be bent eitherbecause it has a memory and wants to flex back , Plexi can be bent with heat and it will hold it's shape lexan scratches easily too Edited January 16, 201510 yr by Thumpper
January 16, 201510 yr While building materials are being brought up, is lexan/plexi an acoustically appropriate material for an enclosure, if it was the primary building material (not a window)./endthreadjackI built some enclosures out of 1" acrylic (plexiglass) in the mid 90's for some Focal woofers in a car audio install. It seemed to sound fine, but is a lot of work, took forever, I ruined a ton of material and spent hours buffing out scratches... It was also expensive then, I can only imagine now...I really really want to swap my basket out for a TI on my btl when I eventually recone it, would you mind if I messaged you about the details of building a plexi box when I do so? Sure
January 17, 201510 yr While building materials are being brought up, is lexan/plexi an acoustically appropriate material for an enclosure, if it was the primary building material (not a window)./endthreadjack I built some enclosures out of 1" acrylic (plexiglass) in the mid 90's for some Focal woofers in a car audio install. It seemed to sound fine, but is a lot of work, took forever, I ruined a ton of material and spent hours buffing out scratches... It was also expensive then, I can only imagine now... Acrylic was a going thing in that age for show in my area anyways.. seemed to be not much more flexing than MDF.. But the finishing was a pain! But that was the neon light era ...Saying that I feel old!! Clear enclosure neon lights was the trend.
