I was looking for opinions on a how many batteries or Ah ( amp hours ) would people use to supply 20-30,000 watts?
Fyi 2-300 amp mechman alts supplying the bank and 4-cresendo 5500 sub amps in use.
Edited by Bam bam
1 80ah lifepo4 battery form juciebox 1500.00 each
Edited by Antoine'stahoe155+
I've probably said this exact exact phrase a hundred times on here, if you have to ask you probably shouldn't be doing it.
Damn thats so true...hows the build J.
Lol! I'm just interested in people's preference. I have several builds under my belt. I'm not new to large battery banks and running multiple alts. I'm just curious as to the wide veriety of answers I would receive. Thanks in advance to all that reply.
Another vote lithium :)
:suicide-santa:
I would say a Single 80ah Lithium from Juice Box, then another 20ah under the hood. Each 80ah is $3,000 but only weighs 80 pounds. I'm assuming the 20ah will be  around $700.
Appreciate it! I been waiting on a solid answer.
I've followed your build on YouTube and FB.. Nice work I'm looking forward to the next one.
Sencheezy I told you...you had fans looks like a potential juicebox sells...
