Posted February 22, 201511 yr I was looking for opinions on a how many batteries or Ah ( amp hours ) would people use to supply 20-30,000 watts?Fyi 2-300 amp mechman alts supplying the bank and 4-cresendo 5500 sub amps in use. Edited February 22, 201511 yr by Bam bam
February 22, 201511 yr 1 80ah lifepo4 battery form juciebox 1500.00 each Edited February 22, 201511 yr by Antoine'stahoe155+
February 22, 201511 yr I've probably said this exact exact phrase a hundred times on here, if you have to ask you probably shouldn't be doing it.
February 22, 201511 yr I've probably said this exact exact phrase a hundred times on here, if you have to ask you probably shouldn't be doing it.Damn thats so true...hows the build J.
February 22, 201511 yr Author Lol! I'm just interested in people's preference. I have several builds under my belt. I'm not new to large battery banks and running multiple alts. I'm just curious as to the wide veriety of answers I would receive. Thanks in advance to all that reply.
February 24, 201511 yr I would say a Single 80ah Lithium from Juice Box, then another 20ah under the hood. Each 80ah is $3,000 but only weighs 80 pounds. I'm assuming the 20ah will be around $700.
February 24, 201511 yr Author Appreciate it! I been waiting on a solid answer. I've followed your build on YouTube and FB.. Nice work I'm looking forward to the next one.
