April 20, 201510 yr Author Wait, so no more 6th? I was actually quite interested in seeing that pan out. Every time I turn around everyone is building what they call a 4th order lately, there are so few 6th orders that are successful it's eye opening when I see one it peaks my interests. yes its still gonna be a 6th but here in a few weeks when i nut up and spend the $240 on the aeros im gonna need lol Good deal! I know I put off my entire build because I needed the adjustability of Bill Lolo's pyschoports. Now I still have the enclosure, but I sold the subs. Now you really got my interest! lol Keep up the good work. thank you sir! much appreciated Sick, sick,sick. Love this build. thanks man! im gettin real close! stay tuned This is a true build log...nice updates man yes it is for sure! i learned from combing through hundreds of logs.. loved the detailed ones i could learn so easily. so i do the same now so others can learn from me
April 20, 201510 yr Author started bodyworking the port plug in 6 sp4s all ready for action starting to make the loading wall all one piece sanded smooth starting to look like a build........ glassed the last internal seams to make sure its 110% sealed and strong as shit. taking a few hour long nap then gonna get up and finish the box and load woofers so i can test
April 29, 201510 yr Author Off to J.E.C.A.R to get some shit done My mentor Daniel Powell working his magic with my amps he was using a fuckin spatula to pry some wood off lmao in there like swimwear, plexi and trim panel to come soon so at one point we were haulted, couldnt tighten down my lugs onto the wire due to the allen being so big so we went and got one, and welded it to a 13mm socket lmao just imagine clean wiring and LEDs.. soon soon termporary BS battery rack/arm rest lol, voltage drops from 15.1 to 14.9 full tilt.... on one battery at 1200 rpm.. im wired at .67 people lol TIP OF THE DAY, dont let anyone else touch wiring... even something as stupid as RCA's......... stupid expensive lesson, that is all. moving on trip up to crossfire to get the amp repaired
April 29, 201510 yr Author i apologize for the terrible quality some much better videos will be getting posted soon.
May 2, 201510 yr So bedlinger on the roof helps with less flex alot and do it matter if its rolled on or sprayed on just woundering
May 3, 201510 yr So bedlinger on the roof helps with less flex alot and do it matter if its rolled on or sprayed on just wounderingMass is what will help control rattles like that, so I'm guessing roll on would be far easier Edited May 3, 201510 yr by SpeakerBoy
May 3, 201510 yr So bedlinger on the roof helps with less flex alot and do it matter if its rolled on or sprayed on just wounderingMass is what will help control rattles like that, so I'm guessing roll on would be far easiermass is one of the dumbest ways to control rattles
May 3, 201510 yr So bedlinger on the roof helps with less flex alot and do it matter if its rolled on or sprayed on just wounderingMass is what will help control rattles like that, so I'm guessing roll on would be far easiermass is one of the dumbest ways to control rattlesim not going to trying it i was just wondering thats all...
May 3, 201510 yr I didn't say it wouldn't help, but that mass doesn't help rattles. Flex is not rattles.
June 8, 201510 yr Author evening bitches, been having fun getting shit done slowly but surely the last few months, shits coming along. having small problems but part of it i guess.. anywho, picspole got paintedfriends made a meme of me lmfaostarted my doors, almost done with them nowpicked up some 24s for stupid cheap rolled my front fenders
June 8, 201510 yr Author rims on looked so sick but i was rubbing hard in the front so had to take off the 2" drop spindles and put the factory ones back on back to enclosure work, sanded to 320 on the DA UV leds in camera doesnt capture the actual look for shit smh whites on alot closer to how it actually looks in person all cleaned up anddddddddd the 8k went again, BOOOOOOOOO, on perfect voltage too, dropping to 14.7 from 15.1 its RELIABLE replacement lmao
June 8, 201510 yr Author still not sure what the problem is but cf 8k is going bye bye and im getting 6 1700s, 1 per sub @ .7 each amp
June 8, 201510 yr Author shots from the show this past weekend Edited June 8, 201510 yr by lownlouddd
June 11, 201510 yr What did you use for paint in the box? Nice build, if I had an suv I'd be doing something very similar with sp4s Edited June 11, 201510 yr by SacredTanakh
February 24, 20169 yr Admin nice build, I really like what you did with the LED strips in this build. looks great.
