By 4th order are you referring to 4th order vented, or 4th order bandpass? And if bandpass, why?
  • Replies 78
  • Views 9.6k
  • altoncustomtech
    altoncustomtech
    The small gain in power isn't worth the stress it's going to cause everything, and definitely not for a daily setup. Stick to 1 ohm per amp, you'll never be able to hear a difference and all your equi
  • From what is written here, I wouldn't recommend going over the rated limit of the sub or the amp. Why are you wanting to throw so much at them? Why are you wanting to run the impedance down so low? Wh
  • frogcase2002
    frogcase2002
    With the right enclosure you would be really surprised using just one of the amps
If you reread his last post he stated what he means. By fourth he means 4th order bandpass.
Op just a heads up a ported box is a 4th order vented enclosure and a bandpass box is a 4th order bandpass enxlosure. So just saying 4th order doesn't specify the exact enclosure you want, hope that helps.
Thanks, I just noticed that I did not specify.
fyi - i decided to go with a removable port.  I am going to try 2 8" aero ports to start and will change it accordingly for tuning.
