Posted May 27, 201510 yr Would odd numbers sound better than even numbers or louder1 vs 23 vs 45 vs 6I no cone area plays apart but if all was on the same amp...what would the out come be.
May 27, 201510 yr What did you just sayI'm rollin, your comment was the first thing I've read this morning roflNah, it's purely cosmetics and personal preference. I've always been a sucker for those triple twelve angled sealed boxes, but other than that, I like evens. Edited May 27, 201510 yr by SpeakerBoy
May 27, 201510 yr All in the install! Don't see where a x amount of sub's would have anything to do with sounding good. 2 sub's in the right box can sound better/louder in the right enclosure than 4 four in a shitty one!
May 28, 201510 yr with my balls. More seriously, the question should be somewhat moot from the get go. Every situation is different and ALL are easy to model so if you know your car, power potential at certain loads, you can figure it out rather easily.
May 28, 201510 yr I had 3 12"s that did not net half the output of 2 12"s with 3/4 of the power...All in the build.. Cabin gain can be your best friend in a install and cancelation can be you worst enemy.
May 28, 201510 yr I had 3 12"s that did not net half the output of 2 12"s with 3/4 of the power...All in the build.. Cabin gain can be your best friend in a install and cancelation can be you worst enemy.great point but how do you find your cabin gain point and other than flex what causes cancelation?
May 28, 201510 yr I had 3 12"s that did not net half the output of 2 12"s with 3/4 of the power...All in the build.. Cabin gain can be your best friend in a install and cancelation can be you worst enemy.great point but how do you find your cabin gain point and other than flex what causes cancelation? Read up...They are many factors.. http://www.caraudio-forum.com/forum/topic/20006-cabin-gain/
September 4, 201510 yr Thanks for the good info, I have noticed so many different sounds while turning my box in the truck. Up fire, to rear fire and foward firing.it seems up firing works best in my particular vehicle
