Posted September 23, 201511 yr I can pick alternators for $20 at my local yard, for an extra hundred odd amps would getting a bracket fabbed be worth it? Not planning to exceed 3k rms for a year or so. Just a hifonics brx 2k and a taramps 250x4.Suppose I'm askin, how much would a bracket and a longer belt run me?
October 2, 201511 yr Author Definitely, now as far as the bracket goes, depends on the motor. What vehicle?I have a 1998 Mercury Mountaineer, with the 5.0L V8
October 3, 201511 yr Author Where can i inquire about a double or triple alt bracket?And do i just splice the factory wiring or is there a harness?
October 4, 201511 yr Nobody makes a bracket and the expense to do so negates the frugality of the pick a part alt. You should be able to fond a quality 200 amp alt for that for $250.
October 4, 201511 yr I have a friend I used to work with and he runs 8 junkyard alternators on his old truck. It's ugly as hell but it does work.
October 5, 201511 yr Author Nobody makes a bracket and the expense to do so negates the frugality of the pick a part alt. You should be able to fond a quality 200 amp alt for that for $250.I can get a triple alt bracket, run three oem alts for the time being, and wheN I get my lithiums I can switch to singersHow can you tell me no one makes a bracket? Out of all the builds I've seen on here alone, I call bullshit. People fab multi alt brackets. Edited October 5, 201511 yr by SpeakerBoy
October 5, 201511 yr Well, I had a response typed out, but I won't even bother. If you "knew" all this already, why did you ask theother question? Neer, that's why.
October 5, 201511 yr Author I asked if it was worth it, like, what do people usually chargeFor a triple alt bracket
October 5, 201511 yr Why are you asking a question you already answered?If you can get a bracket, why are you asking us? We all bullshit.Neer.
October 5, 201511 yr Author *facepalm*For reallll quit shittin on me lmao Where can I get an estimate on a triple alt bracket for the 5.0, and what do I about the wiring harnesses, can I just splice them together or do I need a device?I supposed that's what I meant to ask in the first placeI have a friend with a cnc....is it so expensive because they need to know the dimensions of the motor as well and have to precision machine it? I mean, its on my list of things to do anyway, and for forty* bucks I can have the extra amperage until I can afford the Singers and lithium batteries. *minus the cost of the bracket Edited October 5, 201511 yr by SpeakerBoy
October 7, 201511 yr I'd say run a single stronger alternator. Try to match one up at a junk yard for a Ford Diesel engine that puts out more than your stock. I know, you have a Mercury, but it's built by Ford.
October 8, 201510 yr Author I'd say run a single stronger alternator. Try to match one up at a junk yard for a Ford Diesel engine that puts out more than your stock. I know, you have a Mercury, but it's built by Ford.Worth it to just snag 320 or 370 and call it a day then? Shooting for solid 14.4v at full tilt. Don't plan on more than 4-5k rms for a decent while.Hifonics 2k, taramps 250x4 and I think I'm gonna put a power strip somewhere in the back for tools n whatever maybe a NES or something. Considering a light bar but that's just an impluse buy, I don't leave the city much. Edited October 8, 201510 yr by SpeakerBoy
