Posted June 13, 200619 yr due to a recent trade i now have 2 x rl-ps im way more into sq ....L then spl. my favorite box desighn for 2 drivers would be the 'wicked one' www.decware.com, but its desighned for 10s? and im not getting much help with the question, if i scale up a dual folded horn desighn by approximately 1.2 will it effect performace (sq) badly? anyone know a great sq desighn that will get loud and remain true to sq performance? straight sealed in my experience is not as good as a desighn that controls the air movement in fron t of the driver (bandpass, horn etc) help! off 2500 wrms
June 13, 200619 yr Admin my RL-p loves 2 cubes at 27hz, blends really well and response is very smooth but output is not crazy loud.
June 13, 200619 yr I wouldnt waste your time with the wicked oneGreat SQ design....low tuned ported.<{POST_SNAPBACK}> Uhh...not a waste of time.You can use the same design as the 10" wicked one with the 12's. Just extend the baffle out a bit and it will be fine. I have heard two RE SE 12"s in there. Very nice.The wicked one is a very nice box with a very nice sound and flat responce. Definatly work it if you have the room
June 13, 200619 yr Author I wouldnt waste your time with the wicked oneGreat SQ design....low tuned ported.<{POST_SNAPBACK}> Uhh...not a waste of time.You can use the same design as the 10" wicked one with the 12's. Just extend the baffle out a bit and it will be fine. I have heard two RE SE 12"s in there. Very nice.The wicked one is a very nice box with a very nice sound and flat responce. Definatly work it if you have the room <{POST_SNAPBACK}>do you mean build it like the 10" version and angle the baffle to get the 12 in there? or scale it by 1.2 , not sure what you mean? more imfo please.
June 13, 200619 yr I wouldnt waste your time with the wicked oneGreat SQ design....low tuned ported.<{POST_SNAPBACK}> Uhh...not a waste of time.You can use the same design as the 10" wicked one with the 12's. Just extend the baffle out a bit and it will be fine. I have heard two RE SE 12"s in there. Very nice.The wicked one is a very nice box with a very nice sound and flat responce. Definatly work it if you have the room <{POST_SNAPBACK}>do you mean build it like the 10" version and angle the baffle to get the 12 in there? or scale it by 1.2 , not sure what you mean? more imfo please.<{POST_SNAPBACK}>We built the 10" version and added the 12"s. You could also scale it up if you wanted to. Definatly wouldnt hurt.
June 13, 200619 yr Author I wouldnt waste your time with the wicked oneGreat SQ design....low tuned ported.<{POST_SNAPBACK}> Uhh...not a waste of time.You can use the same design as the 10" wicked one with the 12's. Just extend the baffle out a bit and it will be fine. I have heard two RE SE 12"s in there. Very nice.The wicked one is a very nice box with a very nice sound and flat responce. Definatly work it if you have the room <{POST_SNAPBACK}>do you mean build it like the 10" version and angle the baffle to get the 12 in there? or scale it by 1.2 , not sure what you mean? more imfo please.<{POST_SNAPBACK}>We built the 10" version and added the 12"s. You could also scale it up if you wanted to. Definatly wouldnt hurt.<{POST_SNAPBACK}>the box is only 13.5" tall (that includes the outside mdf x 2=1.5"), there is no room for 12s unless you build it bigger than the plans?
June 14, 200619 yr I wouldnt waste your time with the wicked oneGreat SQ design....low tuned ported.<{POST_SNAPBACK}> Uhh...not a waste of time.You can use the same design as the 10" wicked one with the 12's. Just extend the baffle out a bit and it will be fine. I have heard two RE SE 12"s in there. Very nice.The wicked one is a very nice box with a very nice sound and flat responce. Definatly work it if you have the room <{POST_SNAPBACK}>do you mean build it like the 10" version and angle the baffle to get the 12 in there? or scale it by 1.2 , not sure what you mean? more imfo please.<{POST_SNAPBACK}>We built the 10" version and added the 12"s. You could also scale it up if you wanted to. Definatly wouldnt hurt.<{POST_SNAPBACK}>the box is only 13.5" tall (that includes the outside mdf x 2=1.5"), there is no room for 12s unless you build it bigger than the plans?<{POST_SNAPBACK}>Hmm.. I will have to ask Doug what he did. It was the 10" box he used maybe he added an inch or so that I didnt know about.Either way its a great box design.
