June 21, 200619 yr Try 5ft^3 tuned to 34Hz.<{POST_SNAPBACK}>if you got the room...my favorite box for was 6.5ft.
June 21, 200619 yr Author I will probably try the bigger boxes later. For now I want to experiment with the best sound out of smaller boxes. Probably try a box 3ft sealed per sub with bracing and rounded inside corners. Then 3ft tuned to about 30hz. I won a company that builds custom shipping crates so I have all the resources around me all day. all sorts of ideas go through my head while Im workin.
June 21, 200619 yr Author welcome to SSA, how about some install pix? <{POST_SNAPBACK}>Here is the install with Kicker subs. i will update it when I get the new box built.http://www.cardomain.com/ride/2350773
June 25, 200619 yr welcome to SSA, how about some install pix? <{POST_SNAPBACK}>Here is the install with Kicker subs. i will update it when I get the new box built.http://www.cardomain.com/ride/2350773<{POST_SNAPBACK}>Sounds like you need to EQ the drivers a little. Get some decent measurement equipment and try to flatten out the response. I'm sure once you do that you'll have the best sounding system you have ever heard!
June 25, 200619 yr you will probably want more than a single 4" port for each 15 Edited June 25, 200619 yr by bimma85
June 26, 200619 yr Author you will probably want more than a single 4" port for each 15 <{POST_SNAPBACK}>I was meaning 2 4in ports per sub. Not even sure that will be enough though. Actually if I do a vented box I will probably just build a huge vented box and install it only for comps or something like that.
