Posted June 21, 200620 yr Isnt gonna be strappable????????????What the hell.Any other news about them.Are they gonna make more power?Are they gonna run lower ohms?
June 21, 200620 yr yup... the reason they are not strappable is because when they are standalone, it puts otu less power than the 05 MD2.
June 21, 200620 yr Admin yup... the reason they are not strappable is because when they are standalone, it puts otu less power than the 05 MD2.
June 22, 200620 yr Basically....The older MD2D's put out more power than the new ones.But when you strap the new ones thats whern the put out the power
June 22, 200620 yr yea. so they are scrapping the strapping deal so the md2's will still put out the same power
June 22, 200620 yr If you really need that much power, and it has to be strapped (you can't accomplish the same result with a pair of MD2's running stand alone), just get a pair of MD3's. . . .They are not that much more $$$ and they will be available soon!Brian
June 24, 200620 yr If you really need that much power, and it has to be strapped (you can't accomplish the same result with a pair of MD2's running stand alone), just get a pair of MD3's. . . .They are not that much more $$$ and they will be available soon!Brian<{POST_SNAPBACK}> nG
June 24, 200620 yr Author If you really need that much power, and it has to be strapped (you can't accomplish the same result with a pair of MD2's running stand alone), just get a pair of MD3's. . . .They are not that much more $$$ and they will be available soon!Brian<{POST_SNAPBACK}>Sounds like a good idea
June 29, 200619 yr jerems... i think you should re-read all your posts in this thread lol, you got me SO CONFUSED
June 30, 200619 yr why is that? lolokay i am talking about a strappable md2...a standalone strapping-capable md2 will put out less than a non-strappable md2however 2 strapping capable MD2's strapped together will put out a good 3800+ watts (im just guestimating the number here)i hope that makes sense
June 30, 200619 yr why is that? lolokay i am talking about a strappable md2...a standalone strapping-capable md2 will put out less than a non-strappable md2however 2 strapping capable MD2's strapped together will put out a good 3800+ watts (im just guestimating the number here)i hope that makes sense<{POST_SNAPBACK}>And so for that reason, they decided to not make them strappable, so that the new standalones will still put out as much as the older ones? Is that correct? Basically, I just want to know if the newer ones will be weaker than the older ones or not.
July 5, 200619 yr yes the new ones will put out the same as the old ones.<{POST_SNAPBACK}>Original non- strappable MD2 will be re-run until end of the year. At which time the MD3/AX3000DE strapping circuit will be used in design.End of Aug The 25th anniversary, limited edition MD2 and MD3 will be here.
July 6, 200619 yr yes the new ones will put out the same as the old ones.<{POST_SNAPBACK}>Original non- strappable MD2 will be re-run until end of the year. At which time the MD3/AX3000DE strapping circuit will be used in design.End of Aug The 25th anniversary, limited edition MD2 and MD3 will be here.<{POST_SNAPBACK}>so does that mean you cant get an MD3 until Aug 25??
