Posted May 26, 20169 yr Quick question for all of you who are a lot smarter than me! My math told me it wasn't enough but I wanted to double check with you all. If my sound system drives 4100 watts will a 270 amp Max 200 idle alternator be able to support it? Especially accounting a/c etc. If it will that would be awesome, but if not I'll just go with SSA Icons instead of xcons. Ps I know I could probably get multiple alternators but it would be a tight fit, and personally don't have the capability so it would probably cost too much.
May 26, 20169 yr I think you would be fine. Just make sure you watch your voltage. And batts wont hurt
May 26, 20169 yr 4 hours ago, Cj the newbie said: Quick question for all of you who are a lot smarter than me! My math told me it wasn't enough but I wanted to double check with you all. If my sound system drives 4100 watts will a 270 amp Max 200 idle alternator be able to support it? Especially accounting a/c etc. If it will that would be awesome, but if not I'll just go with SSA Icons instead of xcons. Ps I know I could probably get multiple alternators but it would be a tight fit, and personally don't have the capability so it would probably cost too much. it's NOT going to work........... you NEED a FLUX CAPACITOR ........................
May 26, 20169 yr Xcons dont need full power anyway, music is dynamic as well so you wont be seeing 4100 watts. Install a voltmeter and let her rip, if voltage drops than upgrade batteries to AGM if you havent already and add one if need be. Also do the big 3 wiring if you havent yet.
