1 hour ago, nem said:
Thank you Sean. :)
I have everything but a car lift and CNC cutter.
I have a framing nail gun, what do you use?
I use a brad nail gun, 18gauge or 16gauge will do the trick. Something to keep the wood together while the glue dries.
  • Replies 106
  • Views 13.6k
On Friday, August 05, 2016 at 8:49 PM, nem said:
Latest update, thank you Sean for sending me this.
I need one of these to have hanging around myself.
Love the shop,if I had one the wife would have to beat me out of it...lol
On 8/11/2016 at 9:31 PM, nem said:
On 8/11/2016 at 9:33 PM, nem said:
Tomorrow if I have time the hole will be cut for the sub. I am not carpeting this at this point, but that may change. Depends on the customer.
Looking solid so far sir! Way to break in the new workshop.
On 8/12/2016 at 11:55 AM, nem said:
Box update
Looks really solid.  Is this from my suggested specs on the site or the 3D model?
Thanks Aaron.
It just so happened the designs you sent me fit the application very well. Small ported design.
Thank you, mine does the same.
  • 4 weeks later...
  • Popular Post
I currently have this in the 4runner on a sundown 125.2 and am quite impressed how the ICON sounds on such small power 4oo watts.
4 minutes ago, Randal Johnson said:
Nice work Nem !!! Clean enclosures !!!
Thank you. :)
Very nice! Definitely cranking out good work.
Thank you. :)
1 hour ago, j-roadtatts said:
The Enclosure looks super dapper! Keep up the killer work!!
Thank you. :)
  • 2 weeks later...
Looking great, going to  see what I have in my stock pile that we can have fun with.
Sounds good!
I was going to put a forced hot air system in for heat after I insulated, but I ran into this to heat the garage when I am out there. I have seen them in use on construction sights, but figured they cost more than I wanted to spend. Walking at the fair today I came across them and figured I would give it a try.
http://www.val6.com/
Sweet lord that's huge!
Watch the dust & fumes in the air with that open flame. On many of the sites I'm on they use ones fed by natural gas. But that's usually a huge building. Regardless that looks like it's gonna cook you in that shop.
No worries I keep my shop clean and this will be located in the furthest corner at a safe distance. 111,000 btu should keep things nice once I insulate the shop.:)
Finally getting around to building ported enclosures for the Evil mids. These are simple ported boxes .71 cubs @ 58hz. The boxes will be covered in carpet and the mid will be running full range off of a Yamaha 797 for people to listen to.
