Posted July 25, 200619 yr I have an i/s 4065 and am debating whether or not to run this for my Z6 comps. It would have to be bridged and that would be at 3ohms...is this possible for the 4ohm stable amp or a definite no-go? Thanks
July 25, 200619 yr Are the comps actually 3ohm or is that just their DC resistance. If so the impedance will be higher and everything should be fine.
July 26, 200619 yr Author M5...the Z6 comps from Boston are a 3-ohm nominal resistance set. I'm thinking that if it were 2-ohm it would be a problem...but 3-ohm may let the i/s4065 still be bridged. OR, am I dreaming and there is no way two bridged channels can survive at 3ohms?This all determines if I will need a new amp or not, so thanks for any advice.
July 26, 200619 yr I just had to look 3 ohm impedance is correct, as for resistance I am sure they are lower but that matters not only impedance. I do not have experience with the 4065, if it isn't overated you could have a slight problem. On the same note if you set your gains a bit conservative so you aren't running full power out of it and she doesn't get hot it might be okay. I didn't recommend before though because I am not sure on the I/S's at all.
July 26, 200619 yr Author Thanks M5...seems you are on top of all of my questions lately. Appreciated, especially since I'm a noob.Anyhow, I'd be interested still to know from someone that has some i/s experience if this is possible...or if I'd be wasting my time. I pm'd Flakko about some new US Amps, but seems he hasn't been online in a few days. I'm waiting on word from him...So with that, anyone else with info regarding brigded channels at 3-ohm? Thanks!
July 26, 200619 yr Admin From my experience, most A/B amplifers that are 4 ohm stereo are stable at 2 ohm stereo. So if you are at 3, I would venture to say you would be ok as long as you stick with what ///M5 mentioned about amplifer care.
July 26, 200619 yr Denim he is bridging it though....if you weren't bridging I am sure it would be fine.
July 26, 200619 yr Author correct, my questions is about an i/s4065 BRIDGED. so, this amp states it is only 4 ohm stable on 2 bridged channels...but does anyone suspect I would be ok at 3 ohms?
July 26, 200619 yr Admin Denim he is bridging it though....if you weren't bridging I am sure it would be fine.whoops miss read that one.
July 26, 200619 yr I still "think" its probably going to be okay as long as you are gentle....but with no I/S experience you shouldn't listen to me. Anyone used one of these at a lower impedance?
July 26, 200619 yr Author Ok, well, unless I get a different amp until the time it's all installed, i'll give it a shot and see what happens! I'll post results... thanks M5
