Posted August 8, 200619 yr i woulda thought with all the rl-p fans here that know what their doing (i dont) i coulda got some interest in a box design but no-one has offerd? i have paypal and want a seriously good sq.....L design for 2 x rl-p. or should i got to toxic bass?
August 8, 200619 yr Batter up! Good luck 60! You might also want to check out the following links I just posted [here].
August 9, 200619 yr sorry if i missed this on a previous thread, but what are your design goals?do you want a wider bandwidth? what do you want for your fh and fl?do you want high output?do you want a 4th order, 6th order, or 8th order bp?how much room can you give up?Qts/Qes is so low that a 6th or even 8th order bp would likely work best.
August 9, 200619 yr Author found this today, gonna build it.will report in a week or so.http://www.decware.com/newsite/invertedwedge.htm
