Posted October 4, 20169 yr 2008 GMC Yukon JVC arsenal 4v Headunit SSA 6.5 EVIL mids in front doors Soundqubed deadener in front doors Second Skin speaker tweakers SMD dual ANL fuse holder SSA EVIL 18"s D2--(2) Ampere Audio 3800 @ .5 ohm SKY HIGH wire throughout- 2 runs of 1/0 cca 1/0 OFC grounds and from battery to amp 4g ofc on subs an to amplifier SHCA 1/0 inputs an 4g to 8g inputs ILL CUSTOMZ battery terminals an 1/0 inputs XS XP3000 battery Knuconzepts RCAs enclosure is 12 cubes before bracing an sub disp tuned to 29hz
October 5, 20169 yr Love the build man, how does it sound? What tweeters are you using in case I missed it.
October 5, 20169 yr Is this just a burp vehicle? I only ask cause I see your wired down to .5ohm. And if not how do those ampere amps do at .5ohm do they get hot, shut down, or draw a lot of current?
October 6, 20169 yr Author Stock tweeters for now. No its daily musical build I wired low to account for rise. On stock electrical I drop to 11.5 but that's when charging at 12.7 stock alt is computer controlled.
October 6, 20169 yr 6 hours ago, levee000 said: No its daily musical build I wired low to account for rise. Beware where you get advice. No such thing as rise. ALL drivers have an impedance curve and if you play in the wrong spot you won't be happy.
October 7, 20169 yr Wow ! That's an ...evil setup ! You must be happy. Down the road, you will be able to add a second amp for your subs. How do you like the mids : are they loud enough for all that bass ?
October 8, 20169 yr Author On Friday, October 07, 2016 at 7:30 AM, Notorious97200 said: Wow ! That's an ...evil setup ! You must be happy. Down the road, you will be able to add a second amp for your subs. How do you like the mids : are they loud enough for all that bass ? I plan on another amp yes for the subs. Need better electrical first lol. Mids Def need more power but they do hang off headunit power.
October 8, 20169 yr On 10/5/2016 at 8:08 PM, levee000 said: Stock tweeters for now. No its daily musical build I wired low to account for rise. On stock electrical I drop to 11.5 but that's when charging at 12.7 stock alt is computer controlled. I wouldnt count on that saving your amp. I never wire below recommended, unless it's a burp vehicle where you can adjust for rise playing sign waves.
April 12, 20178 yr Author Havent done any changes yet. Yukon was wrecked a day after xmas. But not totalled. Mechman 370 is on the way to fix voltage.
April 13, 20178 yr 18 hours ago, levee000 said: Havent done any changes yet. Yukon was wrecked a day after xmas. But not totalled. Mechman 370 is on the way to fix voltage. bad news , but good news for the new alt !
April 15, 20178 yr Author Its fully repaired an driving. Alt shoukd hopefully ship this week. Have a show this up comin weekend i wanna attend
