Posted August 29, 200619 yr can someone tell if these can be bought online anywhere? also can are these .7 ohm stable and finally what kinda actualy power dot hey put out? take in?
August 29, 200619 yr nope they cant be bought anywhere online, you gotta go to an actual store for the ax line. they are .5 ohm stable IIRC but dont know the numbers....
February 28, 200719 yr can someone tell if these can be bought online anywhere? also can are these .7 ohm stable and finally what kinda actualy power dot hey put out? take in?they are stable down to .5 if i'm not mistaken. PM flakko on here he might help you get one. Great guy to deal with!:edit:dont like the new layout of the website >< didnt c the replies. Edited February 28, 200719 yr by shiipseki
March 6, 200719 yr The AX 3000DE is being replaced with the AX3200DE which has 240 volt output vs the old ones 70 volt out. Moreover it has 38% better damping Factor vs AX3000. The AX 3200 esily puts out over 4000 watts RMS into a 1 ohm load
March 8, 200719 yr The AX 3000DE is being replaced with the AX3200DE which has 240 volt output vs the old ones 70 volt out. Moreover it has 38% better damping Factor vs AX3000. The AX 3200 esily puts out over 4000 watts RMS into a 1 ohm loadWowI second what denim said!
March 9, 200719 yr Well another new amp to consider for the big boys...Denin what do you think the price range will be for this since i notice you are an authorized Us Amps dealer
March 9, 200719 yr Would (9) Optima D31T's and a 260 amp alternator be acceptable for (8) AX3200DE's? Brian
March 10, 200719 yr Brian I would do two 260 alt for that type of power, don't forget the bullet proof vest and the hard hat....nose bleed anyone LOLMan Denim, when you gonna finish bricking your house bud then you can order some AX series woohooo Edited March 10, 200719 yr by theabunai
March 20, 200718 yr so how much do they run at the ax3000de and ax1000 specifically?if your asking about price the AX3000de (discontinued) i believe retails at around 3 grand
